Question about Frigidaire Washing Machines
Frigidaire Mod.fwt445ges2 Went into spin with out of balance load and shut down. Will not start or run in any cycle. Door latches, light comes on, timer doesnot advance in any setting nore does pump.
  • 3,037 Answers
Well redistributing the load and unplugging it should hopefully reset it.
Otherwise the balance sensor is the problem which is internally in the motor tachometer, and thats whats causing it to not work.
If you have a 5 yr. warranty on your motor contact Frigidaire and ask them to send a authorized Frigidaire Lead tech. and I'm sure he will verify what I'm saying.
Please let me know if you have any more questions and I would be glad to help
Posted on Jun 06, 2008
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Scholar:
  • 110 Answers
Remove any clothes from the machine any unplug the wm for 10 min to allow the processor to reset it self. then attempt to restart. if it does not reset you need to have a tech look at it
    Brigadier General:
  • 6,966 Answers
Initially, try to manually unload contents including the water. Thereafter pls try a full hard reset? IThat is unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours). Of course doing a hard reset erases all glitches as well as user settings and configurations.
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
I have a Frigidaire FTF530ES1 front load washer that doesn't spin or agitate. The door lock light comes on and I don't think it is that. It fills with water, then you can hear the clicks for each cycl
Good Morning Vickie,
I understand that your Frigidaire washer, model# FTF530ES1, will not spin or agitate. I also see that the door lock light came on so you checked the door latch, due to it not unlocking right away. Now, you have removed the back panel and restarted the cycle, to find out that the motor is not coming on. There is a possibility that it could be the motor, or it could be something completely different that is causing your washer to not spin or agitate. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it is not spinning. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer stop spinning
Hello Kathy Murphy - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Will the drum manually rotate (when it is not in use)? If it does not, then the washer drum may not be balanced and/or possibly have a broken shock. Is the door securely latching? Supposing it is not, then the door latch assembly will need replacing. However, since it is such a complex unit, I strongly suggest contacting a professional to accurately pinpoint any potentially more serious issues like the timer, pump or control board not communicating correctly.
Jan 27, 2013 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
Instructions
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Not spin
Hello elvis 1964
welcome
Hello harley1964dm
Welcome
You said, Washer will not spin at end of cycle
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
132 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
