Question about ASUS K8V-MX Motherboard
HELP ABOUT K8C-X motherboard
My motherboard cannot detect the SATA harddisk on...
so i cannot reformat my pc as well
but in boot options im sure i can see the Sata drive i have but in
main menu of my bios it indicates disabled or no detection of my harddisk
how can i configure my bios to it i can detect my SATA on my board so i can reformat my comp....thanks
  • thun Jun 06, 2008
    thanks
    President:
  • 2,351 Answers
Hi thun, Unplug the power cable from the PC.
Please reset the bios. This is shown in you're user manual on page 1-17. (If you no longer have you're user manual for the Asus K8V-MX MB you can download it from Asus by clicking on this link):
http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
Remove the SATA data cable & clean both ends of the cable with a few drops of alcohol on to a cotton swab. Than clean both SATA ports on the motherboard using the same method.
Also clean the SATA power connectors in the same fashion. (Allow time for the alcohol to dry).
You can help it dry using some canned air.
Re-connect the SATA data cable & SATA power cable to the SATA drive. (Check all other connections within the PC for good connections before closing case). (SATA data & power connectors are easily knocked loose, so be careful).
Plug the power cord back into the PC & boot the PC. Enter you're bios. Check the main menu & make sure the bios has listed the SATA drive. Than go to Boot menu. Page 2-27, 2-28 in the manual. Make sure you see the SATA drive listed here. If you are sure the SATA drive was listed in the main menu than it must also be listed in the Boot menu.
If it is not listed in the Boot menu than there is a problem with you're bios. You're board is warranted for three years from manufactures date. Please call Asus tech at 1-812-282-2787.
M-F 9:00AM to 5:00PM EST. You will need the serial number printed on a white label located on the pink LPT port. You can see this only from within the PC. Asus will ask for that S/N to determine if you're board is still within warranty. If it is, make sure you get a case number & instruction before ending the call.
Good Luck!
Mike
Posted on Jun 13, 2008
  • Mike Peluso
    Mike Peluso Jun 13, 2008
    Sorry, there is no Asus or any manufacture for the K8C-X motherboard.
I have a Intel D865GLC and it will not boot! The green led light on the motherboard is lightning and the CPU-fan is rotating but there is no screen on the monitor and the computer is not boot A have tried...
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 13, 2009 | Intel D865GLCLK Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
Booting problem
Check your harddisk connectio to mtherbord.reconneect both cable sata and power supply to harddisk.then check in bios your harddisk is detect or not.
Mar 21, 2009 | Intel Motherboard
BIOS cannot detect SATA harddisk
Most motherboards have multiple plug-ins for Sata drives. Try another plug in. This will typically solve this type of issue.
Dec 30, 2008 | ASUS P5LD2-VM Motherboard
Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Dec 11, 2008 | Mercury P4VM800M7 Motherboard
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Pc wont boot up after reformat.
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
Sep 24, 2008 | E-Machines eMachines Desktop PC
Primary master hard disk error
i also need help
my motherboard cannot detect also my SATA harddisk
my Mother board is K8V-X but in boot options i see my harddisk
but in main menu no SATA..
so thats why i cannot reboot or reformat my pc
May 29, 2008 | ASUS K8V-MX Motherboard
ASUS K8V-MX Motherboard Logo
108 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
