Bosch wfl 2000 problem
Hi all
40'c quick wash selected. Got a problem with washer. Switch on water enters powder compartment and wash cycle begins, once finished it drains then rotates clothing back and forth for about 5 mins then stops and active light flashes, softner is still in centre compartment. No power was put to solenoid Y2 or Y3 (y2 main wash Y3 prewash) after it drained. If i pressed start it just did the rotation thing and faulted again. I poured water into drawer and pressed start, machine completed wash to the end.
Tried 60'c + prewash and nothing happens just sits there and eventually active light flashes. Get 200v on solenoids when active light is flashing.
Is the control board faulty?
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
Kindly check the water level sensor. once this parts has the fault it will not spin, until it detect that the water level was set to normal level.. that why when you pured additional water to the drawer it works.. coz u have by pass the entrance of water to the gauge..
check if there was blocking on the way to the sensor.
Posted on Jun 13, 2008
    Scholar:
  • 110 Answers
Your control board is fried change it out otherwise you will be chasing parts all day
  • 1,879 Answers
It is not doing what it's supposed to do.
power is not routed properly - replace the board
Bosh Axxis WFL 2060 operates only on quick wash and warm water!
If you cannot switch cycles then the selector switch board or main circuit board can have faulty componenents and will need to be tested with a multi-tester
Jun 03, 2012 | Bosch Axxis WFL 2060 Front Load Washer
I have a bosch axxis washing machine. The three compartments at the top are not marked. The middle compartment is the smallest. Where do I put my detergent, where do I put my fabric softener and where do I...
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Now, methinks you could do with a manual- if not for now, for later!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Where do I put the detergent & the softner in my Bosh Axxis washer? It has three compartments at the front
John C
May 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The pump on the Bosch WFB 2000 front loading washing machine doesnt seem to be pumping all the water out, it leaves about 40mm of water in the drum. It though pumps and seems to be working, as it does pump...
  1. Check the filter is clean.
  2. Check that the outlet pipe is completely clear of debris and soap / detergent scum.
If this does not cure the problem then it may be there is soimething trapped in the water pump or thst the pump is actually defective which will mean a new pump is required.
To keep the machine clean of waste build up and to keep any bad odors away
  1. Remove all items from the washer.
  2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  3. Close the washer door and dispenser drawer.
  4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  5. Press Start and allow cycle to complete.
  6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  7. Repeat the cleaning procedure monthly
Sep 12, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch maxx 2860 won't do a quick wash anymore
The timer sticks at one place.
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
Mar 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing m/c does not take softener during washing cycle.
Hi. Assuming the washer has completed the rinse sequence, there is a possibility the dispenser part of the valve could be faulty. I assume that you have put the conditioner in the right compartment of the dispenser.. If all else seems to be o/k, I recmmomend thay you once again thouroughly strip and clean the dispenser..
The other possibility is that the hole where the water comes in at the top of the dispenser is blocked.
You need a stiff piece of wire with a hook on the end and poke each hole that you can see in the top of the dispenser compartment
This should solve the problem
Please leave feeed back.
Thanks
Dec 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
