Question about KitchenAid Dishwashers
Kitchen aid dishwasher fuses
A couple weeks ago the power went out on my dishwasher, and a friend told me it could be a fuse. I can not find one anywhere..
The model is 9743964...If you couls help me!
thanks
Lyndsey
  • 413 Answers
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing. It will not look like the type of 'fuse' you may be accustomed to. It could be a round or bullet style.
Posted on Jun 06, 2008
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
The start button on my KItchen Aid Built in Dishwasher KUDI01FLSS2 will not start, there is power and the control lock is not on. It just will not start
I had the same problem although my dishwasher quit working in mid cycle. Once it quit, there was no power to the unit. I replaced the thermal coupling fuse and that solved the problem.
Dec 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Kitchen Aid dishwasher was running and we had to open door to remove something. Door was closed and button pushed to restart. No power at thr panel. Checked for power to the dishwasher. OK There is...
The thermal fuse is clipped onto the conrtol board and to check it ya would need to disconnect power to teh dishwasher and use a multimeter and check for continuity on it here is what the thermal fuse looks like oldtech2332_150.jpg
GENE
Oct 31, 2011 | Dishwashers
No power kitchen aid dishwasher mod kuds01flss6 what do I check first after checking the door switch?
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a
kitchen aid dishwasher mod kuds01flss6 you appear to have a concern with no power to the control, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
8193762)
Here's a helpful link below to a video from "repairclinic.com" to assist in changing (or simply checking it as shown in the second link) the fuse kit...it generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
http://www.youtube.com/user/RepairClinic#p/search/0/jdlVbTXm8SY
http://www.repairclinic.com/PartDetail/Thermal-Fuse/675813/679723
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Oct 12, 2011 | KitchenAid Dishwashers
Door locked after self cleaning&panel went blank
NEVER use the self cleaning feature, again!!
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGRS807SSS Gas Kitchen Range
It hasn't been used much and a couple of months ago it ran just fine. I went to do a load of dishes and it is just dead. Nothing is working. I flipped all the breakers to see if that was the problem and it...
flip every wall switch in your kitchen,while having door latched and turned to a run mode of some sort.be sure to check under kitchen sink for any hidden power switches as well.8 out of 10 ge d/w with this issue usually revert back to a wall switch
Nov 13, 2009 | GE Nautilus 24" Built-in Dishwasher
I have the same problems.
sounds like you have a blown thermal fuse.
Jun 24, 2009 | KitchenAid KUDR01TJ Dishwasher
No power for my Siemans SL84A dishwasher
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
Mar 03, 2009 | Siemens 24 in. SL84A305UC Built-in...
Whirpool quiet partner dishwasher seems to have no power
Ok there is a thermal fuse mounted on the control board that shuts down when it gets too hot. Did you run a sanitize cycle? Even if customers dont use the sani cycle which i recommend the fuse may open due to poor wire connections. The new fuse kit comes with a new harness and new connectors. Check the old fuse to be sure its bad. Dont remove the connectors from the new switch at all - dont disturb them and they will work better.
Dec 02, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
145 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
