Question about Dryers
Dryer has power, but no signs of it.
Unit is .
Possible cause of problem:
Last time I heard the unit attempt to turn on, it started to but stopped shortly after starting. I opened the door and there was a towel caught slightly in the door, which may have prevented drum from turning. (A guess) I don't know if this means my motor could be bad now or a cap could be out (or even if I have a cap on this unit, or even how to get to the motor/cap)
Tested power on both sides of cord, correctly showing power after determining no fuse is out. (240 across both hots)
Read documentation which said to check thermal sensor next. There were actually two similar looking sensors, both of which are correctly -not- open. Tested door switch, which is good as well.
Out of curiosity, I tested power before and while holding on switch, and the voltage changes. (Not sure what that means exactly)
Door light isn't even lit, but I can't recall ever noticing it working (or not working) before.
  • 413 Answers
Measure each 'leg' (neutral to hot) of the power at the dryer. Before holding the switch and after. If the 120v 'disappears' or drops at all, the circuit breaker in your house panel may be bad or there is a bad connection at the breaker or plug receptacle.
Posted on Jun 06, 2008
Dryer starts and immediately shuts off
Hello sdbruflodt- First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dyer wont spin
Hi - When was the last time the ducting in your home was cleaned and confirmed that it has no debris or build up? Turn the breaker to the unit off for 5-6 minutes. Turn the unit's power back on and try a cycle again. If this does not prove to be successful here are a few possible causes that a technician would be required to check: defective heating element, control board, blower assembly, power supply (240v), high limit thermostat or defective sensor.
Oct 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not turn on
Hello Gordon - Try resetting the unit at the household circuit breaker first and then retry the unit. If this proves to not be successful, then typically this is something that a professional would need to diagnose. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limier or door switch.
Sep 16, 2012 | Frigidaire Electric Dryer
My dryer is still heating, but I heard a loud "pop" and the drum quit spinning. Is this a repair I can make with a new switch?
Yes. It sounds like the belt has broken on your unit. Find your manual if possible to be your aid in the belt replacement. If you cant find it, and you are somewhat handy, you can attempt the replacement with no aids. Its not recommended but I have done it before. Please remember, SAFETY FIRST! DO NOT attempt to make any repairs on this unit unless it is UNPLUGGED! Good luck.
Jan 20, 2011 | Roper Dryers
I have a GLEH1642FS1 combo washer/dryer stack unit. I was drying a load and heard a loud pop that seemed to come from the top of the unit. After the pop, the dryer stopped. The light in the dryer no...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2010 | Dryers
Dryer does not start up when the start button is pressed. It makes a click like a relay is closing but no power to the drum motor, or electric heat. unit interior lights up, and controls light up. When...
Your belt is likely broken. Pop the top (held down by spring clips) to inspect. If you see it - try to lift it. If you can not lift it it is ok. If not ok, remove the front cover for complete access to the drive.
Dec 29, 2009 | Kenmore HE2 Plus Front Load Washer
Dryer just stop working
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 30, 2009 | Dryers
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
2000 CHEVY SILVERADO 5.3L FUEL GAUGE PROB.
The problem is in the tank.The sending unit float gauge is worn.Its a factory GM issue.You will Need to replace the sending unit in the tank.I had the same problem and thats what I found.Its real common and this will solve your problem..Its 67.00 Dollars on Ebay..
Jan 27, 2009 | 2000 Chevrolet Silverado 2500
Dryers Logo
102 people viewed this question
Top Dryers Experts
