Question about Asko 24 in. D3350 Dishwasher
F2 code flashing
Indicating too much water in the machine all though no water in the machine, drain pump still running.
  • useanew Jul 11, 2008
    Have the same problem. F2 flashing and can't get it to stop and restart, even after water is drained.
    Scholar:
  • 55 Answers
Have you tried to reset the dishwasher to clear out the error code? Toreset, you hold down the "Start/Stop" button (or "Wash Program" buttonon units that don't have the "Start/Stop" button) for 3 to 5 seconds.This should clear the code. Try running a cycle to see if the problemreturns. If it does, you can, if you are completely comfortable withyour mechanical abilities, remove the toe kick plate, the access panel,the "T"-shaped kick bracket and the galvanized guard plate to see ifthere is water in the basepan. I would only remove these panels if I was POSITIVELY comfortablewith doing it. * To remove the screws, you'll need a 20 TORXscrewdriver. If water is present in the base pan, vacuum with a wet/dryvacuum or soak up with a towel or sponge. Run a cycle and inspect forleaks. If the problem continues, contact a local service center: Toll-free @ 1-800-898-1879. Hope this helps...
Posted on Sep 04, 2008
    Sergeant:
  • 351 Answers
Tip the dishwasher back to reset floodswitch,test for leaks and blockages.
Posted on Jun 17, 2010
Having a problem with a D3350? Want a solution? Buy a new dishwasher!
A D3350 was included in my new home. It was a piece of junk that leaked water causing damage to the basement window directly below my kitchen. I wasted money on one repair call, which failed to fix the problem. I bought a KitchenAid. Now I'm happy.
Posted on Feb 09, 2009
Why is it blinking f2?
Whirlpool
F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump.
Jan 23, 2016 | Washing Machines
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer is giving a code of "F2" & not draining properly.. any idea?
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Whirlpool F2 = Long Drain error code.
Potential Causes:
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not complete the cycle or drain the clothes. It just stops and beeps then flashes an error code like F2.
And F2 translates to: long drain. Make sure the drain hose from the machine is not kinked or plugged. Do you hear the pump running when it is supposed to? Check the drain-pump filter for debris. Replace the pump if it doesn't seem to run. Hope this helps!
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
It keeps F2 me or saying suds I can't remember
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Jan 03, 2010 | Whirlpool Washing Machines
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 is flashing, still in wash cycle
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
Apr 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Asko 24 in. D3350 Dishwasher Logo
974 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
