Question about LG 42PC5D Television
Un-Clear picture my tv does not have a clear picture - it appears to be pixelized along the edge of an image - also the tv station "ghost" in the lower right hand corner is not clear - please help
    Problem Solver:
  • 4 Answers
What types is it
Posted on Jun 18, 2008
LG TV 42LV5500 with vertical lines
T con Board or the LCD panel of the TV is faulty. You have to replace the Tcon Board to confirm where it is T con Or LCD panel.
If you wish to get some details; check the site linked here. Pull up older posts.
Apr 15, 2016 | LG 42LV5500 42 in. LCD TV
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like, to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
Toshiba pjtv picture not clear .. scan module is
if the tv is shifted from one place to another then this problem comes look out for operating manual it given in manual how to reset it
May 28, 2010 | Televison & Video
Colors on the screen are messed up with ghost HITACHI
Its not clear what kind of tv you have but it appears to be older rear projection tv with three picture tube. This problem does occur due to the convergence board going bad. Needs professional help to repair unless you know a lot about soldering ICs. Check out at for more answers on this problem, repairs and costs.
Feb 26, 2010 | Televison & Video
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
258 people viewed this question
Computer Repairing
Computer Repairing
