Question about KitchenAid KSRS25IL Side by Side Refrigerator
"skins" in water, meant to ask Marineo612
I seem to have the same problem though I would describe the stuff in the water dispensed by the fridge chilled water spigot as flexible translucent skins that float around in the water. I too have changed the fridge filters and even removed them to try and flush the stuff out of the fridge tubing but it's still there. But I still have a question if anyone is following this thread. Do I understand NextGuy to mean there's algae in the water source or source pipes supply? We have a well which supplies water to the whole house which is treated and shows no signs of the "skins" in the water up to the fridge. The skins appear only between the back fridge water input and front water outlet spigot. Does that mean the algae is invisible or does not materialize until it gets to the fridge? My kitchenaid model is KSRD25FKWH01 mfg date 07-01
  • bkale680
    bkale680 Jun 19, 2012
    We have had the same problem with our Kitchen Aid refrigerator. Did you find a solution? Kitchen Aid has been no help. We have tried a difeferent filter because we were told that the filter may be reducing too much of the chlorine in the water and that the algae grows as when the water sits in the reservoir
    Scholar:
  • 110 Answers
Sound like you are not having a a algae issue. algae is highly identifible generally black or lime colored sounds like you my have an issue with you water inlet vavle or inlet tubing and water tank detriating
Posted on Jun 06, 2008
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
How to fill it with water.
why do you want to fill with water . food will be real soggy won't it
Jun 16, 2015 | Refrigerators
Ice tray not filling
The unit will not allow water to enter the frig til the temp is cold enough to make ice.
Nov 06, 2012 | Bosch Refrigerators
Faulty water dispenser on stoves american fridge freezer
There is air in the line. Let water dispense until it quits doing as you described.
Aug 26, 2017 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Hello good afternoon, i have a Royal Sovereign water dispenser with a little fridge on the bottom part and the problem i am having is that the dispenser wont release cold water and the fridge wont cool...
It seems likely the two things are connected.
It is very unlikely you could buy anything to fix it but it would be a shame to replace the unit without first checking if the fault is simple and cheap to fix. Unfortunately that would mean finding an experienced handy person or taking it to the local repair shop.
Life becomes cheaper and easier when you include in your circle of friends people who can do stuff you can't...
Sep 03, 2017 | Vacuums
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Jun 13, 2008 | GE GSH25JFR Side by Side Refrigerator
Cold temps
Same thing happened to us. A baffle that conducts air from the freezer to the fridge gets stuck in the "open" position and needs to be replaced. That'll fix that problem but watch for others including the water dispenser that spontaneously begins blasting water across your floor. We've dealt with this twice.
Jun 08, 2007 | GE Monogram ZISS480DRSS Stainless Steel
KitchenAid KSRS25IL Side by Side Refrigerator Logo
199 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
