Question about Compaq Presario 5000 PC Desktop
Compaq wf 1907 monitor speakers--no sound
Hi, one minute I was watching a video and hearing it from the built in speakers, and then the sound just went out? Any suggestions? I HAVE TRIED EVERYTHING THE COMOUTER TOLD ME TODO AND STILL NO SOUND. AT ONE TIME BOTH SPEAKERS WORKED ,TNEN JUST ONE, NOW NO SOUND FROM MY MONITER SPEAKERS. I NEED HELP THIS IS MY FIRST TIME ON A COMPUTER. MY MONITER IS A COMPAQ PRESARIO 150.
    Habit-Forming:
  • 111 Answers
Make sure they have not came unplugged from the computer also on many keyboards there is a mute button, make sure it has not accidentally got pressed
Posted on Jun 06, 2008
Compaq Monitor WF 1907 immediately after the Desktop /Monitor (set at VGA) is turned-on gets stuck at the COMPAQ sign in the center and F10=SetUP, EXC=Boot Boot Menuplus F11=System Recovery all displayed...
Try using your windows cd to boot up the computer and if that does not work then you may need to reset the bios. Inside the case if it is desktop there is a way to reset the the bios. There is a jumper that needs to be switch then switched back that will reset the bios. If this does not work may need to get a new hard drive. The MBR ( Master Boot Record) may have been corrupted.
Mar 26, 2011 | Compaq Presario SR5712F PC Desktop
Where can I buy a cable to connect my WF 1907 to my computer?
dvi(white) or vga(blue)? vga you can get at walmart but dvi is not so widely used. i believe they carry it though.. if not try amazon
Feb 04, 2011 | HP Compaq WF1907 Monitor
How do i get sound to come out of my WF 1907 moniter?
Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and adjust the volume up.
If the issue is not resolved please check the link
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01289551&product=3351970
Aug 06, 2010 | HP Compaq WF1907 Monitor
The volume is too low on my computer speakers
Hi, Mark Here, see I can help.
The 1907 does not amplify your sound it will let you control the volume to some degree but not boost the incoming sound.
If you had amplified speakers b4 your sound card requires amplified speakers.
Best two options i can give is.
  1. If it is a desktop you can install a amplified sound card. Hook to monitor speaker.
  2. Unplug monitor speaker &use amplified speakers.
Just so you know laptops use internal amplified speakers. If you decide to install sound card make sure it is an amplified card.
Hope that fixed ya! know not the best news. Need more help comment back. Please Rate.
Good Luck!
Mar 28, 2009 | HP w1907 LCD Monitor
Monitor going to sleep
Try checking your Windows settings by right-clicking on the Windows desktop, then properties. You will be able to see Display Properties dialog box. Click on ScreenSaver, then click on Power Saving.
Look for "Turn off Monitor.." you can set it to "Never".
Feb 18, 2009 | HP Compaq FP5315 15" LCD Monitor
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Compaq Presario 5000 PC Desktop Logo
143 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
