Question about Amana RanARG7302 Gas Kitchen Range
Trouble with an Amana oven
I have an Amana Model ARGS7650E. The top burners and the broiler all work fine. The oven igniter comes on and heats up, but the gas doesn't come on. Even when holding a cigarette lighter to the burner, it doesn't light.
  • Ricky101 Jul 26, 2008
    I replaced the gas valve. While the burner comes on now, it doesn't light fast and we smell gas. Also, it is very slow to heat up. Watching the burner with the cover removed and the door closed, the flame will go from full to very small and back again. Not very fast and mostly the flame will just barely be visible most of the time.
  • 3,037 Answers
Sounds like a bad valve that needs to be replaced. If that doesn't fix it let me know but 90% of the time this is the problem and the fix.
good luck and let me know if you have any other questions with this
Posted on Jun 06, 2008
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jul 26, 2008
    Well, then with the new information, it seems that you have a defective thermocouple. It goes from the ignition point back
    to the gas valve itself and looks like a metal piece of wire about the
    size of a coat hanger wire. Locate it and remove it. Then take it to
    Lowes or any hardware store and get a replacement for around $8 or so.
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
check the door switch
check the termocouple
hamid
hhamidi56@hotmail.com
Jul 26, 2008 | Amana RanARG7302 Gas Kitchen Range
Amana Model ARGS7650E Oven Problem
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Jun 04, 2008 | Amana RanARG7302 Gas Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
159 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
