Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 55h70 I can not align the the blue & red with the green in the center (#8) on my Toshiba 55h70 TV. At first the picture would distort while watching then I could turn it off and it would be corrected. Now it appears that the green is too far towards the top and bottom in the middle of the screen. (vertically) What could cause this?
  • Toshiba Master
  • 8,617 Answers
Sounds like the convergence ICs are defective and need to be replaced, they are STK392-110 you can get replacement ICs at the following link that include free instalation instructions.
http://servicemanuals.vstore.ca/
Posted on Jun 06, 2008
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Red Color Convergence is off
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2010 | Toshiba 55H70 55" Rear Projection...
My picture is distorted in the bottom left corner of the screen. I can't get the red and blue crosses to line up in the configuration menu. I am guessing the motor that adjusts the projectors is shot. Can...
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Toshiba 55H70 55" Rear Projection...
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
Mitsubishi VS-45609 Blue layer is distorted and seperated
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Dec 30, 2008 | Toshiba 55H70 55" Rear Projection...
Red/Blue line overlay..........
replace convergence chips and limiting resistors
Aug 29, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence ICs
the green is half controlled by half of each of the convergence Ics meaning green horizontal is controled along with the red and green vertcal is controlled along with the blue Ics. So if you have replaced both Convergencs ICs the problem is most likely a resistor that is in the green circuit. You will need a schematic to locate which resistors are in the green vertical and horizontal convergence circuit
Jun 07, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H81 Blue and Red Only
so you missing the green is is either a bad connection on the green crt or convergence amp ic bad
do this first
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
then if that doesnt fix it
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 23, 2008 | Toshiba 55H70 55" Rear Projection...
Can not align color dirvertions on test screen
I think you need a remote to use the convergence features of this set. Does it have an auto convergence feature? And does it work?
Dec 31, 2007 | Toshiba 55H70 55" Rear Projection...
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
