Question about Toshiba gigabeat S MP3 Player
Will not turn own it reads contact manufacturer for repair.
My toshiba s will not turn on or off. It reads contact manufacturer for repair with a yield sign with the number 5 reading inside the yield sign. Is there any solutions you can offer.
Thanks,
Lynn
  • Anonymous Mar 13, 2009
    message tjat says contact manufacturer for repair
The hard drive became disconnected. I took out all of the screws to the outer case (5), gently slid cover down until the small ribbon connector for the power buttons is exposed, unclip and remove. Set aside back of unit (at this point the hard drive might come with it if the ribbon has come out of the back) at the top there is a two screw metal bracket that covers the ribbon connection for the hard drive. Remove the ribbon from the main unit and gently force it back into the hard drive ribbon connector. once fully seated you can reinsert the other end, replace the two screw bracket in a way that holds the ribbon down. Slide the backing back far enough to reinsert the power buttons ribbon connector and then test it before you throw in those last 5 screws.
Posted on Jul 23, 2009
    Problem Solver:
  • 24 Answers
Hey i got that same message when i dropped it from my hand yesterday while getting in my car. it said the same thing with a yield sign... i really thought that the hard drive was prolly damaged cuz of hitting the cement floor hard from 2 meters up. then i took it in my hand n give it a hard shake and hit it in my hand and then it started working fine :D
now mine works good.
hope that helps!
Posted on Jun 07, 2008
Bad Hard Drive - Toshiba Satellite A665-S5170
I suggest you back up your hard drive right away and have the hardware tested for possible replacement.
Sep 18, 2012 | Toshiba MK6465GSX) 640 GB SATA II Hard...
Toshiba Satelite laptop won't turn on ?
take it back and use the warranty or contact the manufacturer if you've been there 6 times then the seller should replace it.
Jul 09, 2012 | Computers & Internet
Toshiba satelite l455d s5796 hinge problems
If manufacturing problem they should repair it might if you try to repair or open the monitor you can't get warranty. Otherwise you can contact for warranty.
Apr 14, 2012 | Toshiba Computers & Internet
When I turn on my gigabeat it shows a picture of a box and a store and says underneath contact manufacturer for repair HELP!!!
I had that same problem before. My gbeat is working fine now after I followed instructions here:
http://www.rockbox.org/wiki/GigabeatSInfo
Read through the link under in Gigabeat S Code Injection Tool. You should be able to dl there the recovery firmware.
Sep 20, 2010 | Toshiba gigabeat MES60VK Digital Media...
Windows boot manager for TOSHIBA PRO L300
You will need an original windows installation disc and not a recovery disc. If you do not have one, then you have the option of taking to a shop that does and have them run the repair utility. Or, if you can find someone who has burned a copy of the windows ultimate boot disc, that will also help in repairing the boot manager and files.
May 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba rear projection tv turns on then turns off straight away
contact the manufacturers or read the manual....try clicking on the remote if ya want...lol
Mar 07, 2010 | Televison & Video
Ionic breeze stopped working won't turn on was very dusty, cleaned it wont light up
Hi.
When this happens, usually the filter must be replaced.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Oct 23, 2009 | Sharper Image Ionic Breeze 3.0 Air...
DVD ROM won't read disks . Toshiba Equium
YOU SHOULD GO THO TOSHIBA SERVICE CENTER AND YOU CAN REPAIR IT ON ANY COMPUTER SHOP
Oct 20, 2009 | Toshiba Equium 100 PC Desktop
Gigabeat MES60VK - Error # 5
It just went off and when it was turned on the screen says 5 in a yellow triangle (Error 5?) Contact Manufacturer for repair. Toshiba could not help.
Did anybody found a solution to this problem yet? is it worthy to try to repeir it? please let me know moisilayo2002@yahoo.com. I really appreciate it. Thanks!
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
Gigabeat screan read contact manufacturer fo repair
You've either got the wrong battery or did something wrong when you installed it. You must make sure that the main power switch at the bottom is turned off.
Nov 02, 2007 | Toshiba gigabeat S MP3 Player
Toshiba gigabeat S MP3 Player Logo
286 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
