Question about Imperial IFS40 Deep Fryer
Looking for a thermostat unit for the Imperial IFS-40 serie : 05159306 what's the part number??
    Scholar:
  • 68 Answers
If you have a manual thermostat,(inside door, knob) your part is
#1175 OPERATING THERMOSTAT (HERMETICALLY SEALED REED SWITCH)
If you need the Hi-limit t-stat --
#1177 HI-LIMIT SWITCH
If you have digital control, with digital temperature control, the unit uses a probe.
#1094 FRYER CONTROLLER TEMPERATURE PROBE
Good luck, Mike
Posted on Jun 13, 2008
I would like to know how old this fryer is model#ifs-40 serial#08195302
The 800 number for Imperial is 800-343-7790. Call them up and ask for warranty/service.. They will tell you with that serial number how old the unit is... Thanks, Susan Restaurant Equipment Outlet,
Cincinnati, Ohio 888-542-5959. We sell parts, new/used equipment and smallwares, furniture, everything you need for a food service establishment. Keep us in mind....
Sep 04, 2011 | Imperial IFS40 Deep Fryer
Imperial IFS-40 fryer. Pilot is lit, but buriners won't come on when the temp dial is turned from off to any degree.
Sounds like your thermostat is bad? We could order you one, however in order to get you a price, I need the serial number also. These are very common fryers,our best seller by far and a good fryer too. But, things happen, and the thermostat is the most common part that is replaced after some time....
Our phone is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We ship parts in 1-2 days, and I can get you a price in a few minutes time, if you call or email me. Thanks, Susan REO
Jul 09, 2011 | Imperial IFS40 Deep Fryer
Late combustion on ifs 40 deep fryer. How do I fix this?
check if the unit receives standard gas pressure as rated on nameplate.
Mar 14, 2011 | Imperial IFS40 Deep Fryer
Thermostate in IFS-40 fryer doesn't work.
VERY easy. First, remove the 2 small mounting screws holding the thermostat in place. These are located behind the knob so pull the knob off. Follow the capillary line from the thermostat to where it connects to the tank. there are 2 nuts to loosen. First, using a 5/16 wrench, loosen the small nut completely. Then loosen the other nut. Now.. inside the frying area the bulb at the end of the capillary line is mounted. loosen the screws holding it and now it is ready to be pushed down and out the hole in the bottom where you loosened the 2 nuts. Reverse the process to install the thermostat.
Tom
Jul 28, 2010 | Imperial IFS40 Deep Fryer
Ifs 40 deep fryer
I have a used fryer, imperial, looks like the ifs 40 but can not find the model number on it. Do you have any idea how I can find the model number?
May 13, 2009 | Imperial IFS40 Deep Fryer
Fryer coming on without turning thermostat on
Imperial Model: IFS-40.
The thermostat is either very far out of calibration or has failed, either case it should be relplaced. The Imperial Part # for the thermostat is 1175.
May 04, 2009 | Imperial IFS40 Deep Fryer
My imperial IFS-40 is burning the door
Is this fryer propane?It sounds like the baffles in the tank are clogged.If you remove a burner shine a light in the baffle,if you see alot of soot use a shop vac and clean it out.Let me know.
Apr 23, 2009 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Imperial IFS40 Deep Fryer Logo
354 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
