Question about Creative Labs MuVo V200 MP3 Player
Help to turn on i press the play button but i cant hear nothing, no music, but when i plug it in the computer and the music files pop on i AM able to hear them. do you know whats the case here.
  • 48 Answers
Try putting in some new headphones it could be falty wiring within the plastic covering.
Posted on Jun 27, 2008
I disconnected my playstation in properly while playing a game and now when i turn it on it wont display anything but the wavy lines it will say ps3 the basic stuff but nothing appears like my game icon my...
try to rebuild the file system within this menu ok
Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
Jun 02, 2011 | Sony Playstation 3 (PS3) Console
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
May 21, 2010 | Finis Swi MP3 Player
I have the altus mp3 player, 1gb, holds up to 240 songs and I cant get it to come one. I have downloaded songs and now will not come on. can you help?
It took me a bit to figure out how to get the music to play. The instuctions that came with it weren't very clear.
* Hold arrow "on" button down to turn on player.
* Use rocker (knob on top) to move to the mode you want. For example, move the indicator to "music".
* Push in on the rocker, not the arrow "on" button to select the music mode.
* Use the rocker to select the song you want to hear, then push arrow "on" button to play.
Dec 28, 2008 | Jwin MP3 Player
Phillips gogear sa6185
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips GoGear HDD075/17 MP3 Player
Sandisk 240 1.0 gb
I had this same problem. What I ended up doing was going into My Computer into the device itself and seeing what showed up. It appears a few new songs I popped on there the day after were appearing but nothing else. I deleted all the files, unplugged it from the computer and let the library update, old songs were still playing. Plugged it back into the machine and voila they showed up.
Aug 05, 2008 | SanDisk Sansa m240 MP3 Player
Stopped playing music
Since you have a MAC, your probably using ITUNES, ITUNES are MP4 format which this unit doesnt play, you have to make sure what your putting on is MP3 audio files:
Here is a guide on how to convert songs to MP3 on ITUNES:
http://www.wellesley.edu/Computing/Idocs/Itunes/convertMP3.html
Once you get the audio files converted, drag and drop on the drive from where they are saved on your computer.
To play the audio files:
hold the play button until red light comes on, then press Play again, light should blink which means its playing.
Jul 31, 2008 | Coby MP-C883 MP3 Player
Cant hear nothing!!!
Yes the problem is coming from the speakers , so take the phone to a repair center and have them replace the speakers for you.
Jul 09, 2008 | Sony Ericsson W850i Cellular Phone
There are no instructions in the instruction manual as to how I transfer songs to the MP3 player. Sorry, but I need MP3's' for Dummies. It's the JX-MP102. PLEASE HELP!
Just bought the JX-MP102 find it difficult to use but was able to download songs from a windows xp laptop - plug the mp3 player into the usb port and turn on just as you would for playing music its screen should light up and the computer will pop up a screen with several options click to start windows explorer and from there you can got to place holding music files and copy them the disk letter which represents  the MP3 player. On my machine my main files are on the C disk and a new D disk pops up for MP3 player. I also have a windows vista machine and it also recognizes the player as a new disk drive just like a flash drive.  Unfortunately I can the player to work for a few minutes at best right now even with the music files successfully loaded and playing so I may return it tomorrow. Hope you have better luck.
   rvwill1930
Jul 05, 2008 | Audio Players & Recorders
I Download music to Mp3 and it says no file on it, but it will play the songs on Windows Media Player.
Try not running the Syn software at all. Try copying the files over manually.
After plugging in the USB cable you should get a small popup that says its connected.
Click on "My computer" and under "Devices with removable storage" you should see a new device called DV.
double click on that and you should see 3 folders. DCIM, EBOOK, and MP3
Copy your mp3 files from your computer into the mp3 folder of the camera and it should work.
Feb 11, 2008 | Jazz DV150 Camcorder
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
Creative Labs MuVo V200 MP3 Player Logo
59 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
