Question about Dell Dimension 3000 PC Desktop
Sound windows xp dimension 3000
Installed windows xp sp2 on a dell inspiron 3000. No sound. Installed driver from dell website, R94481. No sound.
Device manager does not show any conflicts.
Any ideas?
  • 1 more comment
  • Anonymous Oct 15, 2008
    no sound
  • Anonymous Nov 01, 2008
    Replaced hardrive in a Dimension 3000, installed Windows XP
    Professional and have no sound. I go to control panel and the Sounds
    and Audio devices are grayed out saying No audio device installed. I
    tried to install the driver from Dell and I receive a message during
    setup that the Audio driver does not suport your computer hardware.
    There is only one driver and it is the R94481.exe. I did a diagnostics
    and the sound passed the test for the 8 tones. Other than that, I have
    no sound.
  • Anonymous Mar 24, 2014
    I have installed windows XP SP3 and download Driver from Dell website by their model no. but when i run stup file of video driver the error show " The required hardware not found "
I had same problem with my Inspiron 3000. I went into the bios at startup (press F2 ) and changed the audio settings to "auto" Problem solved, works great
Posted on Mar 31, 2009
Replaced hardrive in a Dimension 3000, installed Windows XP Professional and have no sound. I go to control panel and the Sounds and Audio devices are grayed out saying No audio device installed. I tried to install the driver from Dell and I receive a message during setup that the Audio driver does not suport your computer hardware. There is only one driver and it is the R94481.exe. I did a diagnostics and the sound passed the test for the 8 tones. Other than that, I have no sound.
Posted on Oct 05, 2008
  • 407 Answers
Hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver Zone.com then download it
Posted on Jun 06, 2008
How do i get sound back on my computer i have reformatted recently and lost all sound ....i have been on this issue for a week and everything i have tryed...failed please help me i run a dell dimension...
There's a good chance that the drivers that come with Windows XP SP1 & SP2 may not support your sound card. I'm guessing that you're using the onboard sound that comes standard with that configuration. If you're using the default onboard sound you can download the drivers from Dell here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=en&catid=&impid= and install them. If you're using a different sound card I'd need to know which one in order to point you in the correct direction. To find out which sound card is in your system do the following:
  • Go to your Start menu
  • Click on the Control Panel icon
  • Switch to classic view
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the device manager button
  • Click on the + mark beside the Sound & Game Controllers selection to expand it
  • It should list which audio device you have
You can also type in your service code (this is listed on the side of the case on the sticker) and type it into the site at support.dell.com and it will show what hardware that system shipped from Dell with.
Jan 18, 2011 | Dell Dimension 3000 PC Desktop
Desktop - Dell Dimension 3000 - Windows xp - No soundran Dell selft test - checked out fine - Ran sound test available under Dell Tree - sound played through both speakers. Log into windows - tried yahoo...
pen the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Jun 25, 2010 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
Apr 12, 2010 | Dell Dimension 3000 PC Desktop
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
System not accepting sound driver
download the audio driver from dell website of ur windows version.
Oct 23, 2009 | Dell Inspiron 8500 Notebook
No Audio Device
hmm strange.. sounds like plug n play service issue or a bad xp install. with dells usualy u have to install 1st desktop system software then chipset then audio, video, ethernet.
Oct 05, 2008 | Dell Dimension 3000 PC Desktop
No audio
Hi
Quite likely, drivers for the audio controller is missing/not installed.
You did not give any info on the Operating System you installed and the sound card in question; Onboard or PCI Sound Card. I am assuming you have Windows XP or 2000 and using the builtin/onboard sound controller.
If this is correct, you will need to download and install ADI Onboard Sound Driver (Windows 2000/XP) - http://ftp.us.dell.com/audio/R94481.EXE
Let me know how you get on
Mike
May 25, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 3000 PC Desktop Logo
1,269 people viewed this question
Alun Cox
