Question about RCA HD52W56 52" Rear Projection HDTV
Does not work
For about a week the picture would go fuzzy then the tv would completely shut down. We would have to unplug it and leave it set for a while. Then we would cut it back on and it would last maybe 15 minutes or so. Now this week we turn it on and it will cut right back off. It does not even have enough time to bring a picture up. We can not find anyone in our area that works on TV's. This TV is not but a 1 1/2 years old. Any Ideas??
  • RCA Master
  • 8,617 Answers
Sounds like the flyback is out. Thats a common issue with that Model. You can get a replacement flyback at the following link.
http://servicemanuals.vstore.ca/
Posted on Jun 07, 2008
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Won't completely shut off
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
Nov 21, 2013 | PixiModo Reflection 15M 15-Inch Digital...
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
About a week ago it started shutting off i could unplug and plug in again and it would work now i get sound and red screen for a few seconds then shuts off and power light blinks
this sounds like a bad picture tube as it is shutting down becausethey may be drawing too much current fairly common issue with these older projection tv sets
Feb 19, 2010 | Televison & Video
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
No picture or sound on new zenith
It sounds like the set is going into high voltage shutdown, a safety feature which shuts off the set if the power to the picture tube gets too high. Once the set shuts down thus way, you can't turn it back on until you unplug it and plug it back in again.
There's nothing I can suggest that you can do to stop this. This might be due to high power line voltage in the house. There may be a problem in the set and the shutdown is doing its job. Or there may be parts that are defective or out of adjustment that are causing false shutdown. Any work on a TV that involves its protection circuitry is best done by a qualified technician.
If the TV is new enough it might still have a warranty. Check into that first, then look for a servicer in your area and get an estimate.
Nov 23, 2008 | Zenith Televison & Video
Won't turn on
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Sep 25, 2007 | Philips 25PS40S 25" TV
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
