Question about Kenmore 22422 Top Load Washer
Slight noise when running, really rough stop
I had a problem with my Kenmore 80 Series in which the water would not drain. I found that the water pump was filled with material from the inside of a pillow. I cleared all of the debris and when I restarted the machine it seems a little noiser, and when the spin cylce stops, the tub comes to a violent halt. Any ideas?
  • 246 Answers
The violent halt is usually caused by a bad basket drive (basically your brake). This is a very lengthy and complex repair (30 - 45 minutes by a professional) that takes a special tool.
Posted on Jun 15, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
The washer stopped all of the sudden. It was full of water, but even when I unplugged the washer and recycled the machine, it would not fill up. It makes a humming noise when I try to start the machine,...
If it fills and drains then I would suspect the motor coupler is bad, if it's a direct-drive washing machine. Most of them are, kenmore 80 or 90 series.
Oct 10, 2010 | Kenmore Washing Machines
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
you need to check the water pump... it may be clogged with detergent or something to that effect.. or just replace the pump itself..
Oct 11, 2009 | Washing Machines
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce including the motor. It's like the TIMER stopped after the RINSE CYCLE. I think it's the timer.
does it drain after the wash cycle? if it does, then I don't think it's the timer. It uses the same contact there as for the rinse cycle. Do you hear the motor running as if it's trying to drain? If the motor is running, perhaps the pump itself is no good? Just a couple things to check. Hope it helps.
Joe
Sep 05, 2009 | Kenmore Washing Machines
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Kenmore quietpak2 no longer rinse, drain, spin
Sounds like the pump, eighter blocked or needs new pump.Place outlet hose in to bucket to drain, if no water comes out its blocked, if water flows freely possible needs new pump.
Slim jim1
Nov 19, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Kenmore 22422 Top Load Washer Logo
47 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
