Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Problem with Samsung TV
Is this
    Novelist:
  • 132 Answers
SAMSUNG Convergence Problem
It looks like blue convergence. Look at menu, select convergence and see if blue top is bent down on convergence adjust screen. Probably won’t adjust.
Some Samsungs have convergence IC’s on a separate convergence board in the back of the TV. Others have the IC’s mounted on the main deflection board. Either way the board has to be removed to get at the dud IC’s and associated burnt resistors.
You remove the appropriate board, determine if any resistors are burnt or damaged, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality, as it was before IC failed.
If after self or autofocus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
If convergence can not be adjusted properly, you messed up chip install or resistors may be wrong value or open; or it needs major adjustment.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Posted on Jun 27, 2008
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Manual for Samsung smart TV needed model number UN55F6350AF
E-MANUAL - samsung product support network
support-us.samsung.com/.../201306131733051%5E...
Samsung Electronics97 Sound Feedback. 97 Panel Locking. 97 Booting Logo. 97 DivX® Video On Demand.SMART TV Features. Smart Hub. 98 Agreements Required to Use Smart ...
Official Samsung Support
www.samsung.com/us/support/
Samsung Electronics... visual guides, manuals, support downloads, tech specs, troubleshooting, and answers. ... TV & Video. Televisions ... TV & Blu-ray Apps ... Smart Home. Outlets.‎Samsung Galaxy S® 6 - ‎Samsung Downloads - ‎Contact Us - ‎Wi-Fi Tabs SM-T800
Samsung UN55F7500 Flat Panel Television User Manual
tv.manualsonline.com > ... > Samsung Flat Panel Television
Jan 27, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
Jan 13, 2016 | Samsung Televison & Video
My Samsung model pn64f8500afxza tuns on and off buy its self it makes a funny noise just before it happens
    Samsung PN64F8500AFXZA Issues with turning on - AVS Forum ' Home ...
    www.avsforum.com/.../1959809-samsung-pn64f8500afxza-issues-turnin...
    Apr 5, 2015 - 30 posts - ‎12 authors
    TV would turn off and on with no hesitation or delay. .... owners of the Samsung PN64F8500AFXZA model have experienced issues with turning ... Official Samsung PNXXE7000 - PNXXE8000 owners ...
    Aug 8, 2014
    Official Samsung UNxxES8000 Owner's Thread - Page 541
    Jul 7, 2014
    Official Samsung UNxxH7150 / UNxxH7100AF Owners ...
    Jun 10, 2014
    Samsung HW-F550 Soundbar
    Apr 7, 2013
    More results from www.avsforum.com
    Samsung PN60F8500 Crashing / Random Restart Issue ...
    ? 7:42
    https://www.youtube.com/watch?v=IM4fpFD-a3g
    Sep 24, 2013 - Uploaded by ryandev00
    Samsung PN60F8500 Crashing / Random Restart Issue .... Do it have that directional buzz like last year model. ... times it will happen just like yours, even turning off and on non stop 10 seconds apart. ... Samsung PN64F8500: 1080p 600Hz 3D Smart Plasma HDTV - Duration: 1:29. mytvtoday 6,782 views.
    Samsung TV Keeps turning off and on. - Forums - CNET
    CNETHello, If my LN-T4053H TV is off for a long period of time (hour or more, it seems), then when I turn it on, it repeatedly turns off and on by itself for a m... ... This problem is all over forums on the internet, various TV models. Some people re-solder ...Missing: pn64f8500afxza
    Samsung PNF8500 review - CNET
    www.cnet.com > Home Entertainment > TVs
    CNET
    Rating: 4 - ‎Review by David Katzmaier
    May 1, 2013 - Samsung's best-performing TV ever, the PNF8500 series pushes the plasma picture ... Samsung PN64F8500, 64 inches ...... After 25 days of owing a 2014model Samsung tv it randomly started shutting off and on, this was a ...
    Are there still capacitor problems with Samsung TVs?
    www.practical-home-theater-guide.com/are-there-still-capacitor-problem...
    I am experiencing the same thing with my TV turning itself on and off (very annoying).... I had same problem with my samsung smart tv model un40f6300af power off and on. It would ..... PN64F8500 gone a few months after Samsung warranty.
    TV Is Turning Off And On By Itself (Power Cycling)
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 28, 2013 - PN50C550G1F TV Is Turning Off And On By Itself (Power Cycling). If your TV is powering off by itself then powering back on you may need to ...Missing: pn64f8500afxza
    Support - Plasma TV PN64F8500AF ' Samsung TVs
    www.samsung.com > ... > TVs > Plasma TV
    Samsung ElectronicsTurn the Smart Touch Control over so the back cover is facing up. Placing one or two... Placing one or two fingers in the groove, gently pull the back cover off. 3.
    Amazon.com: Samsung PN64F8500 64-Inch 1080p 600Hz ...
    www.amazon.com/Samsung-PN64F8500.../B00BCPH...
    Amazon.com, Inc.
    Rating: 4.4 - ‎407 reviews
    Samsung PN64F8500 64-Inch 1080p 600Hz 3D Smart Plasma HDTV (2013 Model) ....With Samsung's 3D converter, turn 2D viewing into 3D for an amazing ... Stand is amodel of strength and an eye-catching complement to your Smart TV. .... Off axis viewing is spectacular and it's bright room performance is top notch, ...
    Amazon.com: Customer Reviews: Samsung PN64F8500 64 ...
    Amazon.com, Inc.Samsung PN64F8500 64-Inch 1080p 600Hz 3D Smart Plasma HDTV (2013 Model) ....I will admit defeat and will turn off ARC and use an optical cable instead in ... I had my eye on all the Samsung TVs as the 2012 models were released.
    My Samsung model pn64f8500afxza tuns on and off buy its ...
    www.fixya.com/.../t26046430-samsung_model_pn64f8500afxza_tuns_o...
    28 mins ago - My Samsung model pn64f8500afxza cycle turns on and off it also makes a noise before it cycle a on and off, what part do I need to fix this.
    Searches related to Samsung model pn64f8500afxza turns on and off
    samsung pn60f8500
    samsung pn60f8500 manual
    samsung tv power cycling
    samsung capacitor settlement
    samsung capacitor settlement 2015
    samsung tv wont turn on
    samsung tv repair
    samsung tv warranty
    1 2 3 4 5 6 7 8 9 10 Next
Jan 09, 2016 | Samsung Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
Jan 03, 2016 | Samsung Televison & Video
Netflix will not connect??
Samsung smart tv netflix problems. - Forums - CNET
CNETI have an un55es7150 i did all the updates for the TV as well as Netflix, and it works great ... In reply to: Samsung smart tv netflix problems. 1. .... I had tech test my internet connection and he said it was fine. ... I have a PN51d6500 smart LED tv.
Support - LCD TV LN40A550P3F ' Samsung TVs
www.samsung.com > Home > Support
Samsung ElectronicsVisit Samsung today for LN40A550. You'll find product and ... ALERT: Apps notLoading or Smart Hub not Loading Learn More. See More + ... Connect with us.
Oct 15, 2015 | Samsung LN40A550 LCD TV
What is the probability for switching sim in Samsung Corby tv
Hi, If you need to switch the SIM card in your Samsung Corby TV mobile you may need to check whether your mobile is network restricted. If it is free from network restriction you can use any international GSM SIM to it. If it is network restricted You need to unlock it before using any other GSM SIM to it. These are the two probabilities in switching a SIM to your Samsung Corby TV mobile phone. If your mobile is network restricted, You can unlock it safer and easier using unlock code. You can get the unlock code from www.wickedunlock.com/samsung-corby-tv/rs11wp9/ at affordable cost.
STEPS FOR UNLOCKING SAMSUNG CORBY TV
Method 1:
1 - Switch ON your Samsung Corby TV with a NOT ACCEPTED SIM Card.
2 - Samsung Corby TV will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Corby TV shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Corby TV.
3 - Compose : #0111*CODE#.
Oct 05, 2012 | Cell Phones
I need help programing my rca remote to a samsung television
Hi
Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
Code 1004 for Samsung TV Code 1005 for Samsung TV Code 1006 for Samsung TV Code 1012 for Samsung TV Code 1013 for Samsung TV Code 1015 for Samsung TV Code 1017 for Samsung TV Code 1019 for Samsung TV Code 1082 for Samsung TV Code 1104 for Samsung TV Code 1105 for Samsung TV Code 1106 for Samsung TV Code 1171 for Samsung TV Code 1172 for Samsung TV
Hope this helps. If so please do rate my answer.
Otherwise please post up additional details as outlined and I will see what I can find.
Many Thanks.
Sep 06, 2009 | RCA ACC-RCAURC Remote Control
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
