Question about Sharp AL-1655CS Laser Printer
Tractor sounding noise when I turn printer on
I purchase my Sharp in May of 2006. I've always had problems with it and while it was under warranty, I was able to switch out to a different printer. My warranty expired in May of last year. Although this system out lasted the others, I am reading possible solutions could be the fuser or the fuser gear drive.
Can I fix this myself under your directions or do I need to get this done by a technician?
It was working fine, then I decided to print an envelope which I had not done with this printer. then it started making that noise.
Renee
  • RAYNE478 Jun 23, 2008
    IT MAKES A VERY LOUD NOISE LIKE GEARS STRIPPING OR SOMETHING IT JUST STARTED HAPPENING AND WE HAD NO PROBLEMS UNITL THEN IT'S 1 YR WARRANTY WAS UP IN MAY 08
  • Sharp Master
  • 2,794 Answers
This has to be fixed by a technician. The feed gears probably need replacing or another gear could be suspect in your copier.
Posted on Jun 06, 2008
I have a rubbing noise in steering column perhaps at firewall? Does it at very low speed and turning wheel to left. More when backing, more when temps are cold. Had the same exact thing on a 2006 Si
It sounds like a mast jacket bearing but if you have had the problem while still under warranty you should be able to argue successfully for it to still be under warranty.
Oct 12, 2014 | Cars & Trucks
PLEASE HELP!!! Sharp AR-BC320 printer! We purchased this printer and do not have the installation cd that came with it :( Can anyone please please please help?!
If you manage to locate an Sharp AR-BC320 printer driver CD it may not have a Vista driver but it definitely would not have a Wndows 7 version and Sharp would not create one for this old printer.
I have found a lot of people are having problems with printer drivers for old printers with Windows Vista and Windows 7.
I suggest you purchase a new printer that support Vista and Windows 7.
May 09, 2012 | Sharp AR-BC320 All-In-One Led Printer
2006 Scion xB Auto w/ 25,000 miles rattle/ping noise during moderate acceleration at 2000 RPM's. Does not make the noise during heavy acceleration. It began softly at 15,000 miles and has gotten louder. ...
wow -- if your powertrain warranty expires in June then I would be kinda concerned about this problem and maybe take the vehicle down to a different Toyota dealer and have them look at it.
by your description it almost sounds like a valve might need to be adjusted(?),, but it could be something different and more serious.
if you are not happy with the report from the dealer - you can always call Scion direct at (866) -70-Scion,, or (866)-707-2466.
here is also some of the Scion information about a complaint and or warranty problems:
http://www.scion.com/assets/pdf/tc_warranty/tC_Owners_Warranty_2006.pdf
Feb 15, 2011 | 2006 Scion xB
I purchased a Sharp Aquos 32" television Model LC32D50U on 2006/10/26 from a company A & B Sound in Edmonton. The company is no longer in business. I also purchased a 4 year warranty on LCD TV, Parts...
If the extended warranty was bought solely through that company and was not officially through Sharp,you may be screwed as far as the extended warranty since they are out of business.If the warranty was officially through Sharp,it should not be a problem as there should be other authorized Sharp repair centers locally where you are.I take it you're in Canada?I would at least contact Sharp to find out about the warranty issue.I am providing the global link for you so when you call,have your warranty information on hand(obviously).If the warranty is not confirmed/approved or whatever by them,ask to speak to a supervisor about it.They will have better ability about possibly honoring it out of good faith or discounted service or anything.Be as persistent as possible if it gets to this point.Also,there may be an easy fix to your problem,if so they will know(doesn't sound like it though).Seeing how you probably have to open the menu button,scroll to tint,color or contrast,it's not likely to be just a stuck button.That's all I have for now.Hope all goes well eh.Good luck! Greg
http://sharp-world.com/support/index.html
Aug 11, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Newly Purchased SHARP Microwave Oven Model R-315J Now makes Loud Noise..No Microwaves Produced?
If I had to bet, I would say the high voltage rectifier diode is shorted or the magnetron has failed.
But since it's newly purchased, it will be under warranty and I'd let Sharp fix it free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Sharp Microwave Ovens
Venta LW44 - KNocking sound and only 1 of the 2 wheels turn
This sound is could mean that the life of the gear has been used up.
This is a common problem. It is easily fixed for $10 + Shipping. The gear needs to be replaced. Try this link to have someone call you. abdistrsupport@gmail.com
Remove the gear and turn on the unit to see if the noise still exists.
  • If noise stops, the gear and coupling needs to be replaced
Dec 10, 2007 | Humidifiers
Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Nov 06, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Canon i9900 Printer Trouble
Less than a Year ago - You mat have a chancefor a ree replacement under warranty terms - check out where you bougth from [you do have the bill dont you?] Also get on to Canon Tech Support team Also take a look at www.fixyourownprinter.com
May 31, 2007 | Canon i9900 InkJet Photo Printer
Sharp AL-1655CS Laser Printer Logo
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
