Question about Ruud UBHC Air Conditioner
Where can I find stuff about my A.C.?
Hi. I just moved in in Dec. and My RUUD air cond. is dripping water outside and the ac is not cooling well. A repairman put freon in and "fixed" the leak but it is still leaking. He went up into the attic and did something and he said the leak was fixed, but it is still leaking. The unit is a 2003 and is a RUUD achiever High efficiency model# uamb-036ja7.volts208-230, hetz 60, HP 1/3
My email is hogued@sbcglobal.net, Sheryl Hogue
  • shogue1 Jun 13, 2008
    What about telling me what's going on with my A.C. and are RUUD air conditioners bad news?
    Thanks,Sheryl
I have a ruud a/c ,i turn on the a/c and nothing happens ,the fan on the inside or outside are not coming on ,i have checked the breaker ,they are ok.could something be wrong with my programmable thermostat.
Posted on Oct 30, 2008
  • 1,420 Answers
First, complain to the owner of the service outfit you hired to repair the system.
Second, give them a chance to make it right.
Third, if they refuse, ask who their competition is and contact them for service.
Lastly, contact the Better Business Bureau in your area.
Posted on Jun 12, 2008
  • Chandler Ede
    Chandler Ede Jun 13, 2008
    OK, Water leaking out of the indoor unit is normal, from the outside unit is not normal. Is there an ice build up in either the inside unit or the outside unit? Are you turning down the thermostat too low and causing the unit to freeze up? Did the technician fix a water leak or a refrigerant leak? Do you see refrigerant oil in places or do you hear a hissing? Is the unit running and cooling at all? Have you checked and changed the air filter? To help you, the next technician will need additional information. What exactly did the first technician do? Did he braze the leak or just tighten down a valve? Did he clean out the condensate line? I see that my first suggestion did not answer your question to your satisfaction and you will have to start all over again with another service company. They will ask you these questions and more when they start troubleshooting your unit. If I can do anything to try and satisfy you, it would be to prepare you for these questions and hopefully help you save a few bucks by you having the answers. An issue with an air conditioning system is not like having a flat tire. There are many variables when it comes to troubleshooting an A/C system. If you see ice, turn up the thermostat to a setting where the unit does not try and turn on. Turn the fan switch to "ON" found on your thermostat. After a few hours, check to see if the ice has melted. When it is gone, set your thermostat to no less than 72 degrees. If it seems to work for a few hours but gradually starts blowing warmer air, this tells you that it is low on refrigerant or the air filter is restricted or that you have a number of vents closed or restricted. Inspect these items. Inform the technician what you did and I just saved you $150.00 in troubleshooting!
Ac leaks water
Technically it should do that. The air cond system cools the air by removing moisture.
The water should be dripping onto the ground under the truck.
Jul 02, 2013 | 2004 GMC Envoy
All my other AC Units have had a drain directly to the sewer system...usually connected under a sink. Does my Ruud unit only have the drain to the outside of the house? Usually, when the AC is draining...
If you have a CENTRAL air unit, you should have an overflow to a drain in the furnace area. So I don't understand what you are saying about a connection to the drain under the sink!
Do you have the make and model correctly listed? Because with your question it does not agree what I know about the Ruud Central air that you listed.
Aug 08, 2011 | Ruud UBHC Air Conditioner
It sounds like their is water in the blades and its not cooling my room
Tip the AC slightly downward on the outside so that the water can drip outside. If should be a hole for the water to drip away, make sure it's not blocked. Close your windows and doors. As long as cool air is coming out of the AC, it's working.
Jul 27, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
Hello, I have a Ruud 10 seer unit in the condo i rent...it frequently stops cooling. The fan inside never shuts off, but the unit outside won't come on often enough to cool to the temp on thermostat. When...
It sounds like the air cond is freezing up, and as he melts the ice off he evaporator coil you will have air flow again. When the evaporator, (which is the coil that absorbs the heat from your condo) is frozen over, no air flow can pass through it. The evaporator is located either above the furnace or below the furnace. Therefore, the indoor fan will continue to run, but no cool air will be coming out of the vents. What causes it to freeze up? Usually it is low on refrigerant (some people call it freon). If there is a leak in the system, he may charge it with refrigerant, and then in a few days or weeks later have to thaw it out, and charge it again. If this is the case, you might want to request the leak be located and fixed. Another reason it will freeze up is a dirty filter. Or, if the unit did not have a filter in it for quite some time, the evaporator could possibly be stopped up with dirt resulting in poor air flow all the time and and eventual freeze up of the evaporator. Hope this helps you, stay cool.
Apr 20, 2011 | Ruud Matching Split Air Conditioner
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
What is the open air or closed air switch do? --I have an older GE wall air conditioner in an apartment---I hear water gurgling--outside --but there is no dripping--Thanks!
The outside setting is for bringing in the out side air,the closed keeps the air from the ac circulating and closes outside air off.The unit needs to be remove and took out side and cleaned out with a water hose,dirt and debris is keeping it from dripping out side,
Jun 05, 2010 | GE Quiet-Aire Ductless Split System Air...
My ruud silhouette ii gas furnace is blowing regular air. i know nothing about a/c? is it freon?
Check outside unit to see if it is working. If fan is blowing outside put your hand over unit to see if air is warm. If outside unit is running and air is cool. Low on gas or compressor not running. You need to call a service tech to check it out. Also check the brreaker on outside unit. Russ
Jul 23, 2009 | Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
My AC unit outside will not turn on
can you hear anything at all running in outside unit? ruud units have a hi pressure switch located between the 2 tubes going to inside of unit it normally has red button but sometimes the red overing over the button comes off so just look for a piece sticking out that you can push in.
If you do hear other things running in outside unit most lkely you will  have a bad motor or motor capacitor. I would reccomend calling a service company unless you have the tools and meters to check this stuff out. If you do have the tools necessary message me back and I'll try to walk you thru troubleshooting. thanks Peyton
Mar 19, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
166 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
