Question about RCA RTD255 System
Only standby power
The only power i am getting is the standby power, nothing else seems to be working , it was working fine
  • 1 more comment
  • Anonymous Jul 20, 2008
    My Symphonic with BL6600F01013-1 circuit board (a Sylvania number)... was working and suddenly lost power. Plugging out, I hear a "thunk" and plugging in, I hear the same "thunk" but no audio or video. Used the remote and manually pressed the microswitch for on/off. Nothing.
  • end999 Jan 11, 2009
    I have a symphonic with CB#BL6600F01013-1.The picture seems to be getting narrorer,and the top 2" has courser grained horizontal lines going across and working further down with time.Is it a filter?
  • AllenIN May 25, 2009
    Mine is exactly the same as pfers', "only standby power". I have it on a surge protector and nothing else connected to the surge protector was damaged by a "spike", so I doubt the solution is correct about a spike.
    I had this happen once before and by turning off the power to it for a few minutes and then turning it back on, it worked again. This time, no dice.
  • 558 Answers
Most likely the unit has suffered a spike sorry but nothing can be done service will be required
Posted on Jul 22, 2008
Sanyo TV turns on and works but standby light not working
Do you mean that the standby LED does not light up; but the set works fine? Of so, either the standby LED is damaged, or it do not get voltage [due to loose soldering or some other reason]. Anyway, the set works fine. Isn't it. It means that there is no other fault than this. Contact any service technician in this case; to find out the reason. Electro help
Dec 05, 2014 | Sanyo Televison & Video
Cornea 47" Flatscreen won't power on, red standby light lit
Could be power supply failure. Capacitors can be defective without visible indications.
Jun 07, 2017 | pcb Televison & Video
My optimus receiver is getting power but won't turn on
Glad you have made it!! , thanks for choosing Fixya for assistance.
Aug 30, 2012 | Audio Players & Recorders
Unit works fine. However when it is switched to standby for a few minutes or longer then powered up. Nothing happens. Cannot hear the click of something, i assume a relay inside the unit. If the unit is...
I got same issue. Solution is to buy a efergy standby eliminator plug so it can respond to the On/Off signal by cutting off and restoring mains power
Dec 20, 2009 | Yamaha YSP-800 System
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Goes to standby with fast blinking red light after 5 seconds
From my experience you need to replace the Hi power module
Sep 11, 2009 | Denon AVR-1905 Receiver
Sony VAIO VGN-A690 not powering up
Press and hold the power button for about 20 seconds and then press the power button again. If your notebook is set to standby or hiberbate it may have lock up the computer. Hope this hepls
Feb 01, 2009 | Sony VAIO PCG-TR3AP1 Notebook
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
RCA RTD255 System Logo
226 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
