Dell Mickey Mouse Preschool
Problem for Dell Mickey Mouse Preschool (Ages 2-4)
CD-R Problem with Sony CRX140E Drives on DELL Systems
By Horner - usenet poster
How many people are having problems with this drive?
From the 'internal' news group at Dell, it seems quite a few.
Please reply-post if you have information or have encountered
this issue.
Thanks
-jeff-
Same Problem
May 27, 2008
-   dvd/cr-rom won't copy anthing, cd is reading at startup-   Arzella
Solution #1
posted on Aug 11, 2005
Somewhat Helpful)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
Tons of problems here, there's a firmware update on their site at:
http://support.dell.com/us/en/ filelib/download/index.asp?fil eid=2835
In article <Fgxu4.497$eM2.8 @dfiatx1-snr1.gtei.net>,
  "Jeff Minnig" <jeff_min @stercomm.com> wrote:
Sent via Deja.com http://www.deja.com/
Before you buy.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Bray
Rank: Apprentice
Rating: 0%, 0 votes
Jeff, Dell just released a number of driver updates and fixes over the
past week. One is for the Sony CD-RW and from all indications on the
Dell forum it is working! All had the same or similar problems you
noted. G0 to Dell Support Page and downloads...Look in "Patches and
Fixes"...Fix dated 2/29/00 and follow instructions...Good luck! Mine is
OK so far...let me know if he fix works on your unit. PS Dell just also
updated the driver for the GeForce video card and the Lucent DSL modem
John
Before you buy.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
Jeff, here are a couple of posts made by Dell Technicians concerning this
issue.  please read them, and visit this site created by another Dell user
specifically for CD-R & CD-RW drives!
http://the-predator.tripod.com /dell/cdrw.htm
Sony CD/RW issue date 2-4-2000: Dell-Scott
There are a number of reports on this board of errors occurring when
attempting to use the Sony CRX140E-DL "CD-RW" drive. Below, I have listed
what I found to be the three most common errors: I - Drive fails to
recognize the presence of media.
This error appears to be intermittent and a temporary work-around is to shut
the system down for a few moments and then reboot.
After reading through many of the posts on this board, I found some very
helpful suggestions from a "David Goldberg" and "joeseagle". I am suggesting
these reported solutions and take responsibility for doing so. If the
suggestions work, however, they should be thanked.
The following steps have not been tested by Dell and are not guaranteed to
work - proceed at your own risk. These steps, however, do appear to have
worked in 3 different cases, so far.
Fix - (Windows 98 only)
Perform the following steps to install the Sony CD* controller:
1. Go to control panel
2. Choose the Add New Hardware component; select the option to "choose from
a list" the hardware you want to add
3. Add the Sony proprietary "CD-ROM" controller
One more step appears to be necessary for the drive to continue to work
after a reboot (i.e. if the following step is not taken, the customer should
have the same problem again after rebooting):
1. Open Device Manager
2. Open the Properties dialog of the Sony CD controller, and then click
"Resources".
3. Click "Change Settings" to change the IO setting to the highest possible
value it will allow.
(*Note: It appears from the posts that the Sony "CD" controller needs to be
installed, rather than a "CD-RW" controller. The Win98 machine I checked
showed only a CD controller listing, but it did not have a CD-RW drive
installed, either. It seems to me that - perhaps - Win98 would list a CD-RW
controller if it had detected a CD-RW drive? I am not sure if the list of
components Win98 generates is static, or affected by PnP detection. I will
appreciate feedback on this point, or any other.)
Finally, I assume that performing this procedure in Windows NT would work as
well, though perhaps the second step of modifying the controller's resources
might not be needed (?). I do not have the procedure for Windows NT, yet.
Sony CD/RW issue, date 2-23-2000: Dell-David
Dell and Sony are continuing to work on a permanent solution for issues
being reported in the field relating to difficulty reading CD-R/RW media in
the Sony CRX140E-DL drive. Dell and Sony are currently performing
preliminary testing on a softw
Was this helpful?
Yes
No
Solution #4
Not Rated)
Cato
Rank: Apprentice
Rating: 0%, 0 votes
Jeff,
I have had NO problems with my Sony CDRW, like you seem to have.  I am
using Nero and Adaptec EZCD Deluxe 3.5c and Direct CD 2.5d.  I have
added a Maxtor 8.4 HD and a Pioneer DVD 10x40 DVD to this machine and
am using a software decoder.  What kinda problems are you having?? I
have this computer as a Dual Boot with Windows 2000, also.  No
problems with it there either, except that initally, I didn't have
both drives sey as master/slave, but that is USER error.  Good Luck!!!
                                                        Greg
On Mon, 28 Feb 2000 16:21:57 GMT, "Jeff Minnig"
Was this helpful?
Yes
No
Solution #5
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Jeff-
My drive suffered from a case of infant mortality...It simply stopped
working the 2nd week of use (1/15/00 delivery date)---That failure
caused both drives not be recognized by the system....A Dell Tech
walked me thru a reconfiguration---they shipped me a new unit, next-
day- air,and I was up an "running" the following day.
The new drive has worked faultlessly. To date I've made some (10)
copies of dics(data) with no issues.
BTW- the modular design of the Dell chassis is, for the lack of a
better term, way cool. Very well engineered box!!!!
regards-
LOU
Was this helpful?
Yes
No
Solution #6
Not Rated)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
I was on the Dell hotline for over 2 hours before the Tech Support guy
finally found out that there were known problems with this drive.
I have found that shutting the computer off does not always fix the
problem of having the system recognize that there is a CD in the drive.
I am also unable to copy audio files.  The software (don't have the name
right now, I'm at work) tells me the drive is being used by another
software.
I find it pretty outrageous that Dell can say that their systems have
been tested.  This seems like a pretty basic problem to me.
In article <sHzu4.5809$h36.8497 @firenze.visi.net>,
Before you buy.
Was this helpful?
Yes
No
Solution #7
Not Rated)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
I have a new Dell Dimension XPS B800r.  The CD-RW drive did not work at
all.  I followed the instructions in "Alexander's Auto Service" post and
now it seems to work perfectly.  I haven't done a lot with it yet, but
it sees the CD in the drive, I was able to copy audio tracks and also
regular files.
In article <FHEu4.801$NO6.85 @bgtnsc06-news.ops.worldnet.at­t.net>,
Before you buy.
Was this helpful?
Yes
No
Solution #8
Not Rated)
Joey2
Rank: Apprentice
Rating: 0%, 0 votes
I'm using this drive on a 600r system. I have two hard drives on my primary
controller, and the Sony CDRW and DVD w/ software decoder on the secondary
controller. So far (knock, knock) it has worked flawlessly...burns a CD in
less than 10 mins. The drive I have is firmware 1.0h and I have (under
properties) disconnect, Sync data transfer, and DMA all UNchecked. The
system recognizes it as Sony CD-RW CRX140E.
I have no trouble burning while performing other tasks...something I was
unable to do with my previous Dell P200 with HP 2x burner. On a side note, I
did not like the HP, which I now find out is made by Sony...It was replaced
early on under warranty, then that one crapped out. Swore I'd never get
another HP burner...
Was this helpful?
Yes
No
Popular Solutions for Dell Mickey Mouse Preschool
Questions and Unsolved Problems for Dell Mickey Mouse Preschool
Do you recommend Dell Mickey Mouse Preschool (Ages 2-4)?
Answer
Answer
At opening the program daemon tools lite there is a message - is incompatible with windows 7
Answer
Learning Center Spelling and Grammar loads fine but does not run. Get a splash page as if it were... (More)
Answer
How do I open the product trial? There doesn't seem to be a link to do so. They gave me a 25... (More)
Answer
when i try to install Dazzle 03, i get an error HRESULT: 0*800736B3. I is there a solution to over... (More)
Describe your Education and Reference... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Education and... Experts
Top Computer & Laptop Repairmen
in , PA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
