Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego wont power on
We recently had a power outage and we unplugged the cinego from the wall. When the power came back on we plugged it in and now it will not power on. The sound system as well as directv work, just the unit won't. Any suggestions?
  • happyo Aug 07, 2008
    had'nt used projector for quite some time,because lamp needed replacing. Just replaced lamp and unit won't power on
    Problem Solver:
  • 17 Answers
Sounds like a lamp ballast
Posted on Jul 17, 2008
Had a power outage and tv was on when power came back on , heard a pop , now tv has no sound ?
If you have one of the newer flat screen TV sets; power the TV off and then unplug the set from the wall outlet for a couple of minutes and then plug the TV set back in and then power it back up. Lots of newer flat screens have a power supply system that will not reset properly after a voltage spike or a power outage that is a short duration. By unplugging from the wall outlet and letting the power supply drain all the way to a zero (0) setting it usually resets ok when you power it back up. good luck, Dennis
Aug 16, 2015 | Televison & Video
Tip
Wii won't turn on after a power outage.
Hey, recently had a power outage and now your Wii won't turn on?
Well unless your Wii is completely fried from the storm then this should work (It has for me every time I have had an outage).
After you find out it's not getting power then just unplug the power cable from the wall and from the Wii. Normally I unplug it for about 12-24 hours then you go plug it back into the wall, plug it back into the Wii, look at the power button and if it is red/orange then it has been fixed and you should never have a problem with it again unless you keep it plugged in during a thunderstorm/power outage!
This has happened to me about 8 times and this method worked every single time!
on Jan 26, 2010 | Video Game Consoles & Games
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
Jun 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Tv wont turn on
Hello tvlover, The outage actually is not the problem but the spike that happened when your power came back on did the damage. That aside, you may just have a blown fuse. If you are able to and feel comfortable work with electronics, with the TV unplugged from the wall, take the back off of your TV and take a look at the line cord going into the circuit board, this will lead you to a fuse holder, look at the fuse and see if the filament inside has been blown (opened). If the fuse is blown relace it with one of the same amperage and voltage which should be written on the metal part of the fuse. Once the fuse is replaced, plug the power cord back into the wall and power it up. If it comes on and plays, that was your problem and you can turn the TV off unplug it and put the back cover back on, plug your TV back into the wall and enjoy. However if the fuse blows again, that could indicate a problem with a short somewhere in the powersupply path and that will require troubleshooting the set. Now I we have to troubleshhot this TV you will need a multimeter, an oscilloscope, and a schematic of the TV (at a minimum). If you do have electronics experience to this level and do not have this type of equipment, You will have to take the TV to a repair shop. Thank you, and I hope that it is just a blown fuse.
Aug 25, 2007 | Sansui DTV2760 27" TV
269 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
Frank Zabroski
Frank Zabroski
xxxxxx xxx
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
