Question about iRiver H10 MP3 Player
Weird Langauge My iriver H10 has worked perfectly for about 4 to 5 years, but today after it was done charging I turned it on and in my music folder were songs in a weird language. I tried connecting it to my computer to see if that would fix the problem, but instead all it seemed to have done is make the file names longer in this weird language. I would appreciate it if you or any of your staff could help me with this problem. You may contact me with information on solving this problem at IAmSirKibbles@yahoo.com Thank You.
  • 8,596 Answers
Get your manual ready and prepare to fly blind - the manual lists the exact menu order - you must press the up,down,left, right, and select buttons exactly as if the words had been in English and change the language back to English, or do a factory reset in the menu. We will not be able to talk you through this over the computer - get your manual. Available on iRiver website if you no longer have it.
Posted on Jun 07, 2008
H10 wants to lock up
sounds like a hard drive problem...
need to see if you can still access your hard drive through the UMS trick
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
If yes, try formatting the H10 hard drive, reload the latest iriver h10 firmware, and transfer your music files directly to the h10 music folder with Windows file manager.
Download and run Easyh10 free playlist maker, to build and save a playlist to your player.
also see this website:
users
Good luck.
Mar 20, 2009 | iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Cannot delete or add music to iriver h10
I had this problem at first too. the only thing you have to do after it's done syncing disconnect it and turn it on. then afterward go through the options till you find database refresh and wait for it to refresh and all your new music should be in it.
Jan 04, 2009 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
How to back up music library
Plug in your Mp3 player
Double-click My Computer
Double click the icon corresponding to your iRiver
Double click the music folder
Right click the desktop, select "new," and select "folder" - create a folder named "Temporary iRiver Backup" (or whatever name you want to give to the folder)
Start dragging files from "My Computer" window to "temporary IRiver backup" window
There are other ways, but this is one good way.
-Tha Mp3 Doctor
Nov 14, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
75 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
