Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Grinding during adgitating
Grinds and seems to wrap clothes tight around spinner? I replaced a rubber washer that was broke around the 7/16 bolt and can't figure out grinding.
    Genius:
  • 1,028 Answers
Remove that bolt again remove upper part of agitator ckd the "dogs" if worn replace part#80040
Posted on Jun 07, 2008
How do I change a grinding wheel to a Wire wheel on my new grinder # 37823
There is a left handed thread and a right handed thread on the arbors.
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
  • ring test the stone
  • discard the stone if it has been dropped
  • be sure the paper washers are installed on the wheel
GRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
Feb 14, 2015 | Grinders
Why will my washing machine fill, go through wash cycle and most of way through rinse cycle, then stop. When I open lid, clothes are wrapped around agitator very tightly, so unwrap and close lid for m
Your main bearings are gone. Either have it repaired, $$ or "upgrade" to a new one!! I have one of those "new high efficiency" washers and I HATE IT!!!!! You can't wash sheets, comforters, etc,.. they wad up with everything else inside the sheets,etc..eventually you have to rewash everything separately. I would gladly trade this $1300.00 POS for a cheap old style!!
Aug 17, 2014 | Washing Machines
Washer doesn't agitate properly. clothes wrap around agitator
turn the machine over &inspect the belt.Get the make n model # of it &go to an appliance shop give them the #'s and take machine &prop it against the wall on a tilt &loosen the bolts that hold the pump on REMEMBERING where they go loook at the way the belt is positioned &put&match the new belt where it goes,its like a figure 8 around this place &around that place &carefully take the old belt off &attach it and then but the belt on the pump that u took off &take a bar &tighten the slack up on the pump.Install the boths and there u go try it and let me know. I did it once with a Maytag washer when I was 8 months pregnant and The washer is doing just fine.
Apr 06, 2012 | Washing Machines
Precor Elliptical EFX 5.23. Getting grinding noise on both forward and backward strides. It appears the aluminum eddy current disk is rubbing intermittently on the electromagnet. All the bolts seem tight...
There may be a wave washer on the crankshaft that broke - when it breaks, there is too much left to right play in the shaft, so the disk will intermittently rub. Taking it all apart and replacing the washer is tricky - hire a pro.
Oct 30, 2011 | Precor EFX 546i Elliptical Version 4
Agitator does not spin and clothes wrap around agitator then makes a grinding sound
My Kitchenaid M/N# KAWS700G00 will not drain after the rinse cycle neither will it go to the spin cycle
Oct 23, 2010 | KitchenAid KAWS850L Top Load Washer
How do I change a brush? I can't get the axle locked to get the nut off. Can you help me?
Remember if you are trying to change the left side it is a reverse thread nut. You would turn it clockwise to loosen. IF it is very tight, put a wrench on both sides. IF the right side comes loose, remove brush/grinding wheel, and re-install nut, with an extra nut locked to the first one, the put a wrench on both sides again.
Sep 30, 2010 | Sears Rockwell 8 in. 3/4 hp, 5-amp Bench...
Have tried everything, can't get one of the grinding wheels off.
On a bench grinder the wheels turn towards you. This means the grinding wheel on the right side, has a right and nut, and the left side has a left handed nut. If you're trying to remove the left side turn the nut counter-clockwise
Aug 16, 2010 | Delta Grinders
Loud grinding noise and burning rubber smell
Could be damage to drive belt which is made of rubber
Dec 21, 2017 | Kenmore Dryers
Grinding scraping noise and metal strips in the dryer.
yeah id prob just go buy a new drier, cause that one sounds as though its dried its last piece of clothing
May 05, 2009 | Dryers
Washing Machines Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
