Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Powers off When I press the power button the green power light comes for just a few seconds and then powers off. The light does not blink, it is a stready green for maybe 10 seconds. Hope you can help.
  • 5 more comments
  • Anonymous Jun 08, 2008
    Same problem. Can't get the power to STAY on.
  • rjustice2006 Jul 20, 2008
    I have the same problem, push the power button, it lights up for maybe 10-15 seconds, then goes off. No sounds, no blinks.
  • Anonymous Jul 20, 2008
    when i turn on the tv it only stays on for 10 seconds then turns off. the color is screwed up to i can see three color lines when on for those 10 seconds red green and blue.
  • Anonymous Aug 07, 2008
    Mine also powers itself off after 5 seconds.
  • bigsexyshane Aug 09, 2008
    same problem help please!!!! no sound when turned on or picture
  • joser854 Aug 10, 2008
    tv light binks nne times thn repeats its self but no picture or sound even wen unpluged it still blinks for about 5 sec
  • Anonymous Aug 11, 2008
    when i press power light comes on for a few second then shuts off. no picture
  • RCA Master
  • 8,617 Answers
Do you hear any sounds what so ever? Clicks or anything when you press power.
Posted on Jun 06, 2008
The on/off relay does not stay engaged
Based on model number listed here:
If set powers up and green light comes on and goes out a few seconds later:
Press and hold menu and input (source) buttons at same time on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of five times.
If the set has been unplugged you will have to plug it in and turn it on letting it fail (unplugging will clear all errors).
Let me know error code and I will explain--2,2 is most common and most easy one to fix.
Jun 12, 2012 | Mitsubishi WS-65908 TV
Power on fault
A common issue---if set has been unplugged plug it in and when the green light comes on and goes out----on the front of the set press and hold both the menu and input (DEVICE ON SOME MODELS) buttons for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat the code for a total of 5 times.
Let me know what the error code is and I will tell you what it means.
SD TECH
May 21, 2012 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My 8yr. old ws-48511 TV boots up (green light blinks shortly then goes out) after being pluged in, but when you turn it on, the green light comes on then goes off. (will not power on).What is the problem?
When the set powers off after pressing power try pressing the menu and input buttons on the set both in together and hold for 6 seconds to see if the power indicator will blink a two digit blink code which repeats a few times indicating a specific error. Let me know the blink code if any.
Jul 14, 2011 | Mitsubishi Televison & Video
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Mitsubishi xl2u projector
also have the same problem
Jan 29, 2008 | RIM BlackBerry Pearl 8100
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
