My new Samsung 2053BW monitor keeps giving me warning messages about setting the correct resolution (1680 x 1050: 60Hz) but when I go to control panel to reset the resolution I don't get the suggested resolution as an option, just 1600x1200 or 1600x1000, etc). I am using a Dell Dimension 4600 running WinXP with a GeForce FX5200 video card. Also, the font under the desktop icons now looks blurry and is difficult to read.
  • 34 Answers
If a cd came with the monitor use it, if not, download the driver update for monitor and VC.
Posted on Oct 23, 2009
  • 56 Answers
Your screen reserloution on your pc is set wrong
Posted on Jun 06, 2008
Monitor SyncMaster T200 has no image, but LED is blinking. What to do?
That model uses the same power supply board as the Samsung Syncmaster 2053BW and here is a link to a repair guide for that model that should get you going on the right track.
http://www.ccl-la.com/blog/index.php/samsung-syncmaster-2053bw/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 15, 2012 | Computers & Internet
I am using samsung monitor model 740NW and my screen resolution fixed in 1280 by 720 pixels. while downloading of encyclopedia Britannica one message is coming i.e : your current monitor setting do not...
It wants you to set your PC video resolution to the native resolution of the monitor (you may be able to turn off the resolution warning in the monitor on screen setup menu, see your owner manual or download it here: http://www.retrevo.com/support/Samsung-740N-Monitors-manual/id/278bh749/t/2/).
How to set resolution:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps, also make sure you have install correct video card driver in your PC.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 31, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Resolution problem
reset your computer and press F8 F8 immedeatly and keep pressing untill menu appears .then highlight on enable vga mode and press enter your problem will be solved thenk you
Jun 25, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Message received is "Resolution Notifier best resolution is 1280*1024 notification keeps appearing on monitor and I cannot get rid of it. the picture appears fine, why does the message keep appearing?
This is similar to the "out of range" message that many flat monitors give when the resolution is maybe higher than the monitor would like.
It has given you the suggestion for a good reason. As with most monitors flat or crt it is possible to shorten the life of them if you abuse them in this way.
My suggestion is to lower your resolution to the one it offer you.
Aug 25, 2009 | NEC MultiSync LCD175VXM-BK (Black) 17" LCD...
Monitor resolution setting
I would check for new drivers for the video card. They usually have higher resolution abilities for these fancy wide screen monitors.
Jul 22, 2009 | Samsung 943BWX Monitor
I have a Samsung Syncmaster 2053bw. Screen
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
Jul 07, 2009 | Samsung Computers & Internet
Resolution message
Right click on your desktop and choose properties. Click on the settings for your problem monitor and you should find the option to change the screen resolution.
Feb 28, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
LCD problems... Can you help me?
it has nothing to do with your computer, if you put the monitor on a different computer it will do the same thing. the message comes directly from the monitor itself. you have to keep your screen resolution at 1280 x 1024
Mar 23, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
