Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Help Door is locked will not open getting code Dr- door making noise rattle but will not unlock Frigidare freestanding rickntxs56@aol.com
  • 413 Answers
The lock motor may have failed. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. If it is a built-in over, sometimes bending a coat hanger into a hook and sliding from the right side into the lock you can unlock the door.
Posted on Jun 07, 2008
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Code dr oven door won't open sounds like it keep turning
You probably need a door lock mechanism. If you remove the rear panel and locate the lock mechanism (about middle of back) and HELP the gear turn a little it may finish it's unlock cycle. If not just keep turning the gear till the door unlocks.
Oct 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Renting, trying to use self cleaning
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#^%$#^#
Jul 01, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The lock switch is on and door is open-"dr" then "f9" message
Unplug the range and then have someone hold in the door/light button while plugging in the unit again. The locking mechanism should reset itself. Let me know if I can help further.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire Gas self cleaning - lock won't release/door locked
Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
pls appreciate by rating as fixyaa. thanks
Dec 23, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Wife was trying to clean (self cleaning oven) and after setting timer the oven door will not lock and it will now not let us do anything now and it shows a f9 code and when i press bake control, dr shows...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^&^%^%
Dec 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door cannot unlock
I know this response is a bit dated, but I just had the same problem. I removed the back panel. There is a little motor that turns the locking mechanism. I removed that and there is a button on a sensor next to the motor. I turned off the power first, since 220 can kill. Then when everything was sorted out, i turned the power back on, hit the switch on the sensor and everything is back to normal. I also made sure that the lock in front was back at 12 o'clock (the L shaped piece at the top of the door, but on the stove),. It worked for us. Good luck.
Aug 16, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
156 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
