Question about Sony PlayStation Portable (PSP) Console
Stuck cursor am trying to enter a wep key number and the cursor is stuck all the way to the right and it won't stop clicking, help!
Did this work??????
Posted on Oct 28, 2008
    Problem Solver:
  • 7 Answers
You can try using air in the can to clean your stick but you may have to open ur psp up and clean it that way.
Posted on Jun 06, 2008
My cursor won't move and ive tries resetting my
I want you to attach an external mouse and see if you can get the cursor to move. If it does, you have a defective driver. Microsoft can diagnose and fix that problem in three easy clicks. CLICK HERE for the diagnostic and fix.
May 04, 2012 | Acer Computers & Internet
Tip
How to setup WEP on a Belkin N1 Wireless Router F5D8231-4 v5000 1. Log into the...
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.2.1
Note If you change the default IP address then you will need that address to log into the router. Normally it is the Gateway IP. You can check this by opening CMD via the Run command window. Once it is open then type ipconfig and hit enter.
2. Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
3. Next you will click on the Wireless heading then Security in the left hand column.
4. Select “128-bit WEP” or “64-bit WEP” from the drop-down menu.
5. Next you can enter your WEP key manually by typing in the hex values in the space provided, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase. Click “Apply Changes” to finish.
Note a hexadecimal key is a mixture of numbers and letters from A–F and 0–9. 64-bit keys are 10 digits long and can be divided into five two-digit numbers. 128-bit keys are 26 digits long and can be divided into 13 two-digit numbers.
At this point you should have your WEP setup. When you connect your computer to the wireless router you will be prompt for the WEP key you just set up.
on Mar 25, 2010 | Belkin (F5D8231-4) Wireless Router...
Tip
How to reset your linkseys wireless router wep key.
Press start on your computer
click network
right click on the router
click on view device web page
leave user name blank
password - admin - ok
click wireless tab
change wireless(ssid) network name (anything will do, it will assign you the correct one) write the name down.
click reset security, wait till it fully uploads
click save settings
when the page reloads click on security mode - wep
enter 10 didgit code, letters and numbers: ie: abcde12345 (write down the number)
save settings
back to network on the start menu
setup connection or network
manually connect to wireless network
enter network name
enter security key
highlight the one you want
click connect
on Jan 31, 2010 | Linksys Wireless-G Broadband Router
My Vizio HDtv WIFI shows a good signal from my Linskys router but is "unabke to connect" even though I repeatedly enter the correct pass phrase, what is wrong?
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen. If you don't see the Wireless Network Monitor icon, click here.
kb_4285-001_en.png Step 2:
Click the Site Survey tab and select the name of your wireless network or SSID, then click Connect. In this example, we used a wireless USB adapter.
NOTE: images may differ depending on the model number of the adapter.
Step 3:
If the software is asking for a WEP key, enter the WEP key on the WEP Key 1 field.
If the software is asking for a WPA-Personal key, enter the WPA key on the Passphrase field
Nov 02, 2010 | Computers & Internet
Router D-Link DSL-2640R, I require the router wireless WPA security Key
Usually, D-Link Routers default WEP key is at the bottom of the Router. the 10 digit no. ( Incase that is not the one we are looking )
Try this :
Is your PC or Laptop is connected Wireless to Router, Follow this link
http://www.fixya.com/support/r5198336-details_router_or_network
If your PC is wired connected to the Router, try this
Click on START button
Click on Run ( you will find small window to enter command )
Type CMD ( or COMMAND ) and click OK button
( you will see black window on screen )
Type the command where the Cursor is blinking
IPCONFIG ( hit enter key )
From the list find DEFAULT GATEWAY
Default Gateway is IP address of Router
Open Internet Explorer
Enter the No. you find for Default gateway in the address bar ( without www or .com, just the no. ) - Click Go
You will find the Router page open
Incase if it ask you for username and password - type Username = Admin and Password = Password
Under Wireless settings / Advanced Wireless setting - you will find the WEP/WPA Key
Jul 06, 2010 | D-Link Computers & Internet
Cant find my WEP for 2wire331
If your PC/laptop is wireless to Router - try this
OR
If your PC is wired connected to Router, try this
Incase if it ask you for username and password - type Username = Admin and Password = Password ( or the username and password which you have set )
Under Wireless settings / Advanced Wireless setting - you will find the WEP Key
Jul 01, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wep address
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Thanks for using Fixya.
Jul 01, 2010 | 2wire 2700HG-B Router (2700HGB)
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Sony PlayStation Portable (PSP) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
