Question about HP Compaq nc6000 Notebook
HP nc6000 windows hangs up during installation
Hi there can anyone help me with this laptop problem, i received the hp nc6000 with new hardrive and password in bios upon contacting customer for password i was able to enter bios and modify the setting to booting from cd,
now when installing the original windows xp pro cd the installation goes as far as loading all temporally drivers upon reaching to the point of "starting windows" or that section of the installation when it about to detect for previous
windows and or hardive it never reaches this far it hangsup like installation has frozen i repeated several times even upon cleaning the laser pickup and the cd itself still the same results of freezing before installing windows i tried a different cd the same results any help would be appreciated, thank you
  • punkfox Apr 24, 2009
    same issue, hangs at setup is starting windows on a new xp install. Wierd thing is it will install vista just fine so problem is not with memory or hard drive. I belive there some sort of bios security feature that is preventing it but I'm unsure as to how to disable it.
    Sergeant:
  • 458 Answers
Did you check the memory? Sounds like the memory has went bad. Is it noticing all of the memory? Even if it is noticed it could still be going bad or the slot could be going bad. I have seen this happen. Are you positive that the hard drive is not bad. Did you run any test on the hard drive?
Posted on Jun 06, 2008
Driver display hp compaq nc6000 win98se
You can download the video and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
May 09, 2012 | HP Compaq nc6000 Notebook
Trying to reboot my hp mini 210. changed the hard drive and when i try to install windows, it states that there is no hard drive. What do i do now?
Hi there, The reason your laptop isnt detecting the hardrive during install is cause of the Sata controller. I would advise you download the driver for it at the following site and during the windows installation it will ask if you wish to install aditional drivers and you will need to press F6 so that it can load the drivers for the Controller. http://h30434.www3.hp.com/t5/Notebook-Operating-systems-and/Installing-Win-XP-F6-on-HP-mini-210-1066sb-with-Intel-Atom-NM10/td-p/253374
Hope it helps,
Regards
Jul 23, 2011 | HEWLETT-PACKARD Hewlett Packard HP Mini...
Hi can i anyone help me to disable the safe mode on my hp compaq nc 600 plx
click on start - type in msconfig- a new window will open for you
go to the tab boot.ini and you can uncheck the safeboot option from there and restart the computer.
Dec 11, 2010 | HP Compaq nc6000 Notebook
Laptop starts to fire up then shuts down...had it up and running to put Windows XP on it no problem. Has new CPU, battery,, Keyboard 512MB RAM...Can anyone help?
Hi, I posted few days ago with similar problem. I have nc6000 and problem was that I couldn`t thrun it on, the fan starts and orange light was turning on, than it all stops. I received possible solution from BlackMamba, but I did it before and it lasts for a few months. Now, I read about same problem on few blogs and finaly I decide to disassemle it an to find that famous max1987. I found it reflow with heat fan for soldering and guess what...? It works. I am not ready to celebrate yet, but I think that soldering max1987 is the real solution for that problem. Thaks. Bye.
Dec 08, 2010 | HP Compaq nc6000 Notebook
I CURRENTLY HAD MY HP NC6000 NOTEPAD REFORMATTED BUT THERE ARE NO SOUNDS WHEN I LISTEN TO MUSIC OR WATCH A DVD WHAT CUD BE THE PROB?
Hi.
You may have to install audio driver.
Download the file from page below, then run the file when download is complete. The file below is for Windows XP.
HP Compaq nc6000 Notebook PC - Download drivers and software
If you have Vista or a different system, select system here: HP Compaq nc6000 Notebook PC - Download
Jun 13, 2010 | Compaq Computers & Internet
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
I have nc6000 compaq, it does hang
First try to repair ur windows If u can't repair it then just format windows.
First take data backup...............
Nov 11, 2008 | HP Compaq nc6000 Notebook
System hang
you need to install your os at startup
you need to go back into safemode and remove some programs
Oct 31, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
433 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
