Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony tv keeps turning off
My tv keeps going off. seems like it does it on commercials but does it at other times too. I had a faulty DirecTV HD receiver that seemed to start the problem, but I have a different receiver hooked up to it now. but the tv is still turning off.
thanks,
vantiques1@yahoo.com
P.S. this is a 32" sony trinitron WEGA
  • Leigh10uk Jun 17, 2008
    My Sony TV is doing the same thing, switching itself on and off.
    It will come back on if I manually switch it off on the set, but then it just happens again. It seems really random as it happened for the first time 6 months ago then nothing and now it's happened 3 times in two days.
  • Anonymous Feb 13, 2009
    i also have this same problem, very random.....havnt got a clue...any answers
  • 40 Answers
First make sure that the plug of the tv-device is well pluged-in and the voltage in your home is normal.if all this, is ok ,enter in the menu and check the status of `timer sleep`(if `on `than turn it `off`)
Posted on Jul 10, 2008
Remote codes for directv HD DVR and westinghouse tv
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10463, 10623 Westinghouse 00002 dvr hd
Jun 20, 2010 | Sony STRDH810
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
TV Remote code issues
If you go to Directv.com and go to the remote control programming section you can put in the make and model of the tv and it will usually come up with a specific code that may work. I hope this helps a little bit. :)
Mar 31, 2009 | Panasonic EUR7603Z9A Remote Control
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Volumn
Yes
Hold 4 7 2 Buttons When volume is set
Feb 22, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi screen scrolling
Are you using the AV outputs on the Receiver and not the composite grn-red-blue. Do you have the converter jack on the back by the ant. input? what souce on the set are you using for PIP and your main screen?
Dec 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Connecting to projector and direct tv
seems like your directv video is direct to your tv. which directv receiver?
Oct 31, 2007 | Sony DAV-HDX500 System
Programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
Nov 03, 2006 | Directv HR10-250 DTV Receiver
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
484 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
