Question about E-Machines eView 17f3 17" Flat CRT Monitor
E machines eview 17f3 monitor
My monitor started acting up months ago.but i can't take it anymore.
my menu pops up,flashs at me,stays on and changes settings all
by it self.
is there anything i can do to fix my monitor myself or do i have to
throw it away and get another one?
emachines eVeiw 17f3
modes no.786N
i.d.:F
I have a strange issue with my monitor. For some reason any time I boot up a game and get to the main menu my monitor will turn itself on and off. Once I press new game the problem quits. This has happened...
Hello there
try these hints
1) change if you can to another monitor and see if can reproduce the problem, if the problem indeed is there, then your issue come from the video card., but if not, the issue is your monitor video modes changing circuit inside the monitor board. just that
Carl
Apr 24, 2017 | E-Machines eView 17f3 17" Flat CRT Monitor
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
My emachine will not come on-just makes beeping sounds every few sec. is it my hard drive
When you here a beeps during turn on that is a RAM problem. So you need to check the RAM remove it first and clean the dust. Use also the other memory slot
Please pull out the memory and clean the silver coating pins with a rubber eraser to clean dust and stains that causes disconnection.
Apr 02, 2010 | E-Machines eView 17f3 17" Flat CRT Monitor
Pictures on monitor are fuzzy and pixelated. How do I fix this?
Hi shawnpoynter
You may have to change the resolution of your monitor. You may be using a low resolution at the moment.
  • Go to the Desktop, right click,
  • Left click on Personalyse,
  • click on Display settings -
  • choose a higher resolution.
Hope this will solve your problem.
Have a good day.
If this answer work for you, please give a rating.
luciana44
Oct 31, 2009 | E-Machines eView 17f3 17" Flat CRT Monitor
I have no picture on the screen and the blue power button just sits there blinking very quickly.
remove the ram and then clean the ram and then insert it again into the ram slot then power on your PC then you will see your moniter working.
Oct 08, 2009 | E-Machines eView 17f3 17" Flat CRT Monitor
The screen flickers into hour-glass figure.
It's the tube going out. You need to replace it. If you want to stay with CRT monitors, you should be able to pickup a used one for around $10.00 on Craigslist.
http://www.craigslist.org/about/sites
Nov 24, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
Display
Hi again,
It would seem that you posted your problem several times. As stated in my proposed solution in your other postings:
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 14, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
Unlocked e-machines 17f3
It depends on the monitor, but try holding the Menu and Right arrow button together.
Aug 07, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
E-Machines eView 17f3 17" Flat CRT Monitor Logo
294 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
