Question about Lands Phones
HOW DO I GET THE RINGER ON - Lands Phones
  • 3 more comments
  • Anonymous Jul 18, 2008
    ringer off. cant get it back on!!!
  • phyllisbl Aug 14, 2008
    Two of my portable KX TGA270S satellite phones say "Ringer Off Line." Does anyone know how to fix that problem? My phone is a 2-line telephone, which shouldn't make any difference.
  • Anonymous Dec 09, 2008
    GE Model 28112 DECT 6.0 Cordless - -Handset will not ring for incoming call - - on either of the two handsets - - Dial tone, ok - - Can communicate using either handset - - Have checked steps for "Handset Does Not Ring" in Troubleshooting Guide - -
    What else can I check?
  • echoch Jan 09, 2009
    I'd like to turn the RINGER on on my Nortel Meridien 9417 phone. It rings on Line 2, but not on Line 1 and in the setup option, I am told that LINE 1 IS OFF. NO CHANGES MADE. And there is no option for turning the ringer on.
  • jerry6665 Jan 20, 2009
    hello,
    i have the innovage (probably the same as the g.e.) little handheld corded flip phone. it does not ring. how do i turn on the ringer? thanks~
    jerry6665@yahoo.com
    Habit-Forming:
  • 111 Answers
Not enough information.
How do you get the ringer on what type of phone?
Posted on Jun 06, 2008
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
My handset ringers are ''off''. How do I turn them on again? Uniden TRU4985
Hi there try this,
When the phone is in the standby mode, press menu/mute.
2) Press select/ch.
3) Press + or - to move the pointer through the ringer
settings (Ringer Off, Ringer Low, or Ringer High).
You will hear a ringer or melody at the selected volume.
4) Press select/ch, you will hear a confirmation tone.
Ringer Mute (temporarily)
You can temporarily mute the ringer tone. When the handset is off the base and the
phone is ringing, press end. The ringer tone will return to the previous setting starting
[ 20 ] BASICS
• If you select “Ringer
Off”, “Ringer Off”
appears on the display
when you make or
receive calls, or
charge the handset.
Ringer Volume Setup
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Ringer Tones”, then
press select/ch.
You can choose from 6 ringers or 4 melodies:
- Ringer [Flicker, Clatter, Leap Frog, Ping Ball, Reminder,
Soft Alert]
- Melodies [Beethovens9, For Elise (Elise), Merry Christmas
(Merry-Xmas), Home Sweet Home (Hm Swt Hm)]
3) Press + or - to move the pointer. You will hear the ringer or
the melody as you scroll through the options.
4) Press select/ch and you will hear a confirmation tone.
Ringer Tone Setting
• If
Sep 27, 2009 | Lands Phones
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
China mobile ringer problem
sigmatel s890 ringer not working pls give me a solution immedietly
Sep 16, 2008 | Handmark Software MobileLists (950142) for...
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Motorola W 490 individual ringtone
To assign a ring alert (ringer ID) to an entry:
Phonebook > entry, then press
Options > Edit Contact > Ringer ID > ringer name
Note: The Ringer ID option isn’t available for
entries stored on the SIM card.
To activate ringer IDs:
Settings > Ring Styles > style Detail
> Ringer IDs > On
Dec 13, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
346 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
