Question about Acer Aspire™ T180 PC Desktop
Installing memory I have a Acer Aspire AST180-UD400B. It came with 512gb I removed it and added a 1gb in the first purple slot ( PNY Optima Memory DDR2 PC2-5300 w/ silver side sheilds). I just got another PNY 1gb DDR2 PC2-5300 w/out side sheilds. and put in 2nd purple slot.I have two more slots their both orange.But when i turn the computer on the monitor is fuzz and wavey with static you can't read it
U sure it aint bad video card proably wrong ram type dual ch or no ? need help email me drummernick2002@aol.com live help thx nick
Posted on Jun 08, 2008
Ast180-ua381 memory updrade no post
Well, the maximum memory capacity is showing as 4GB with 512MB factory installed. So, what kind of memory are you installing? Are they PC2-6400 DDR2 SDRAM DIMMS? Are they EEC or NON-EEC? The same RAM card has to be installed in the paired slots, but they also have to be at a speed the motherboard can use (PC2-6400 for example).
Jun 23, 2012 | Acer Aspire (AST180-US340B) PC Desktop
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
How i can upgrade the memory for AST180-UD400B ATHLON 64 X2 4200 up to 4gb also how many per slot.
you need to check how many slots it having.. in each slot you can put maximum 2GB memory..means if its having 2 slots , you can upgrade upto 4GB ,
Apr 01, 2010 | Acer Aspire™ T180 PC Desktop
Does the acer aspire 5315 2077 require a certain type of memory?
Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
Adding memory to Acer Aspire 4720z
The RAM memory slot is up on battery .
First open cover above battery plate then fix RAM there .
Jul 13, 2009 | Acer Aspire 4720 Notebook
PNY DDR PC2700 Optima Memory 1GB not recognized by A75 S209
there are basically three different kind of ram so dear if its not working go out there and get the compartible one for your computer pls dont destroy that baby of yours.
Jul 05, 2009 | Computers & Internet
Want to add memory all 4 spots are used
If all of your memory slots are used, you will need to remove the memory that is currently installed in order to increase your RAM. It appears that the T180s were originally configured with 256MB, but they are expandable to 4GB. If there are 4 slots (I couldn't find any documentation with images), you can use a maximum size of 1GB modules for each slot. Just remember that if you are using a 32-bit operating system and you upgrade to 4GB of RAM, you will not be able to use all 4GB. The BIOS will report 4GB RAM, but the operating system will only see approximately 3.4GB.
Jun 07, 2009 | Acer Aspire™ T180 PC Desktop
Adding memory resulted in system failing to boot
Let's get some information about the memory you are using. Get CPU Z and run it with the new memory, then switch back to the old memory and run it again. Write down the results from the memory tab and the SPD tab (all slots being used). You want to make sure that your timings match to give yourself the best chance of success. All of your memory should be DDR2 533 (PC2-4200). SOMETIMES you can use faster memory and it will simply slow down and function. Other times it will not.
Jan 25, 2009 | Acer Aspire™ T180 PC Desktop
How to open desktop to add memory
If you have removed all the screws, it may be that you just need to slide the cover backwards to release the locking flaps. Try pushing the cover in several directions to see if it disengages something.
Oct 27, 2008 | Acer Aspire™ T180 PC Desktop
Installing memory
HI 1008 ,
It is very important to know which branded machine you have ; whether it's Dell , HP etc. I would also require to know the model number and whether you have a Desktop machine or a Notebook.
Anyways , here's a generic guide for your help...
http://www.helpwithpcs.com/upgrading/installing_dimm_memory_ram.htm
Goodluck :-)
Jun 05, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
184 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
