Question about Sony KP-57WS510 57" Rear Projection HDTV
KP-57WS510 57 in stopped working
No picture will come on and the sound only works when I first change the channel, then the sound cuts back off. Also the screen says no signal, but there is because I can hear the channel. What can I do to fix this myself?
  • 84 Answers
Sounds like it is the signal source (cable box or satelite example) also try different inputs, dvd, vcr
Posted on Jun 15, 2008
Sony KP48S65 sound works but picture does not work
I have a suggestion (this is a older set): unplug set, remove back cover.
There is a metal channel V shaped that runs left to right above the boards and just below the 3 large lens---look to see if any white residue trailing down from the lens/tubes into the channel-------GLYCOL.
If see any signs of liquid (even a little) do not touch it--toxic stuff and if it got onto the boards below the set is finished.
Apr 26, 2012 | Sony KP-48S65 48" Rear Projection...
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
Dec 28, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
No picture, just an abstract pattern
it depends if its just that input or the whole tv itself if it works on other inputs it may not be to bad to fix, but if its the tv itself it depends on how old it is and how much you paid. it could wind up costing quite a bit. so take all those things into consideration. it might just be time to upgrade
Jun 05, 2008 | Sony KP-53HS10 TV
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
