Question about RCA RTD255 System
Only standby light comes on
I had the rca trd255 hooked up and everything was working, i unplugged it for a couple of days then moved the whole system and tv to another wall, i hooked it up the same, when i plug in the rca unit all that happens is the power standby light comes on , nothing else i cant get any of the functions to work
Its been happening a lot to this type of systems from RCA I unplug mine and it starts working(sometimes) Im going to retun the darn thing.
Posted on Sep 07, 2008
The tv made a pop sound and now it wont turn on ans both green and red buttons are flashing ..please help
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Aug 11, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My wireless router was working fine for a year until this last weekend when a storm was coming in. We unplugged everything, the power was out for a couple days. When we regained power, we plugged...
depends on whether or not it was plugged in a power strip or not and even in the power strip it could be fried anyway because it depends on wherther or not your house is hooked up to a ground which would be the third prong on the plug send me questions if you need something else
Jun 20, 2010 | NetGear RangeMax WPN824 Router
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Tuner does not work
If you're trying to listen to FM, and are indoors, and your walls are fairly thick, or brick and mortar, chances are you're not getting a strong enough signal.
Modern minisystems like yours come without an external antenna, and use their power cords in lieu of one. Try extending the cord, not coiling it, for better reception.
Other than that, your system may have had a spontaneous problem to its FM tuning module, though not likely.
Aug 29, 2009 | RCA RS2664 Shelf System
RCA surround sound system probs
power supply problem.can you open the circuit board.
Jan 06, 2009 | RCA RT2380 Home Theatre System System
Standby
I had the same problem. I can't fix it, and neither could RCA customer service. The only way I could think of was to find a surge protector extension cord that had a on/off switch to make it easier to turn on. Another solution might be to buy a cheap wall timer, the kind you use to turn lights on/off. That resets it every day and it should be OK.
May 15, 2008 | RCA RS2653 Shelf System
Will not come on.
if you have p scan you need red green blue cables to the tv and both need to be set up to do p scan, it sounds like you have p scan but its not cabled correctly.
Jan 14, 2008 | RCA RTD255 System
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA RTD255 System Logo
251 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
