Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp photosmart C6180 all-in-one
Initialization begining.
One-time ink system itinialization begining.Do not turn printer off or disconnect power during process.
Press OK to continue.
I ready press ok buttom but dont change the status. still the same message and I'm ready have about 10 minuts waiting.
Is this normal?
How long I must to wait?
  • 26 Answers
Restart ur printer
Posted on Jun 11, 2008
I'm getting the following message on my HP Photosmart C6180. Ink system has failed. Unable to copy, receive faxes, or print. Error: 0xc18a0201
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit.
Aug 23, 2011 | HP Photosmart C6180 All-In-One InkJet...
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
The display says "ink system failure", can't
You will need to disconnect the USB cable and then disconnect the power cord. Now open the cover and take out all print cartridges. Next, close the cover and reconnect your power cord (if printer does not come on automatically, press the power button) Now just open cover and insert your ink cartridges. Make sure the ink cartridges have ink in them and they are not empty.
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP ERROR CODE 0XC18A0401
There is one fix for the 0x errors and it doesn't always work but this is the only option.
Press and hold the "*" key. Press the "#" key and release both keys.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Sep 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
106 people viewed this question
Ben Johnson
