Question about Frigidaire GLTF2940ES Front Load Washer
E20 Error I have a Frigidaire GLTF2940ES front loading washer and it has a problem. It comes up with a error of E20 and I don't have the owners manual. Can you please help me with this?
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Posted on Jun 08, 2008
How do you fix e20 code
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Apr 23, 2015 | Frigidaire GLTF2940ES Front Load Washer
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Getting E20 error code on frigidaire front loader. It's 6 years old and has had one main panel board replacement already. Is this the same problem?
You are experiencing a pump issue. Typically a professional is needed to :
1. Check the drain hose for restrictions. Restriction, correctproblem. No restriction, go to step (2).2. Start the washer and checkfor 120VAC at the drain pump.Zero, replace the Main Control Board. 120VAC, remove the pump and checkit for blockage. If blocked, remove the restriction, if not, replace the pump.
Jul 28, 2012 | Frigidaire GLTF2940ES Front Load Washer
What is error 20 on frididaire gallery washer? Clothes just sitting not moving at all?
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washes.
Good morning, No error code is given. bad smell includes coming from the hose.
Jan 05, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer (LTF600ES1) Error E20
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 Error Code
Greetings jeanne1568,
Other consumers have reported this error message and found it relates to your "Coin trap assembly" being blocked, therefore not allowing all the water to pump out. The suggestion out there is to remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
859 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
