Question about Magic Chef CER3740 Electric Kitchen Range
F-1 error code on range
I am getting a f-1 code on the range when you hit reset then it stays off for several hours but then will beep and display the f-1 again. no were can I find what the f-1 code is
  • 3 more comments
  • kellyelyo Jun 30, 2008
    I am having the same problem!!! Please help!!!
  • tyko27 Jul 01, 2008
    I too am having the exact same problem!!!!!!! why cant someone tell us what to do about it?
  • Fun With Music Together
    So Do I - it's driving me crazy!!
  • Hught2 Aug 25, 2008
    My stove keeps beebing it will stop for a couple hours and then start again and every time I reset it it just starts to beeb again with an F-1 Error after a time I have to just turn off the main power to the stove to stop it. What is cousing this and how can I stop it?
  • Anonymous Dec 14, 2008
    Same problem F1 error code...I too have to turn off the range at the breaker. I had a servicemen change the touch pad on the upper right habd part of the range for over $200....lasted two months and started again.....Magic Chef should fix this problem for free. This range should be recalled.
  • 117 Answers
Replace touch pad
Posted on Jul 19, 2008
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
How do i get rid of a 5a6 6ath maytag stove on screen. I have unplugged and replugged after several minutes - still oven does not function at all...help!!!
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Aug 18, 2010 | Maytag MER5775Q Electric Kitchen Range
I get a F-C error code
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective and has to be exchanged under the part warranty.
Jan 22, 2010 | Kitchen Ranges
Error Code F@ on GE XL$$ Range
usually f02 means you have a shorted keypad. does it randomly beep at you if so this is a symptom. you need to replace your keypad
May 29, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Error code F 1 stove beeps
Hello rusalderman,
Welcome to fixya.
Happy to help.
You said, your range has an error code F 1 stove beeps.
This should reset the system.
A Solution to Common Problems
Oven control beeps & displays any F code error (for example
F1) - Electronic control has detected a fault condition.
Press CLEAR/OFF to clear the display & stop beeping.
Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF &
contact an authorized service agent.
This should resolve your problem and reset the system.
Please remember to leave a rating when you are finished.
Let me know. Hopefully it will be a solved.
Thank You , Huuum
Oct 02, 2008 | Frigidaire Kitchen Ranges
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Magic Chef CER3740 Electric Kitchen Range Logo
207 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
