UPCONVERT DVD PLAYER HDMI PROBLEM
I just recently purchased a samsung upconvert 1080p dvd player model number DVD-1080P8 its Anynet+ compatble and i have it hooked up to a 56 inch samsung dlp model number hl56a650 and it is anynet wich means any samsung product like a dvd player with this feature you will bw able to use one remote. this is whats going on i uplugged my tv before insatlling the dvd plyer i bought the hdmi cable from best buy the generic brand around 49 dollars so i plugged the dvd player to the hdmi port to the tv and pluged the tv and the player in turned the tv on and changed the source to the hdmi anynet which automatically turns on the dvd player put transformers the movie in and it starts searching for signal the n the picture comes on but then 5 or 10 seconds later the picture goes blank and the tv says searching for signal keeps doing that so i figured it was the hdmi cable so took the cheap one back and purchased the monster cable for 79.99 unpluged every thing and did the process again same result pictures goes and comes back every 5 or 10 seconds so turned and umplugged everything and plugged my xbox 360 elite with the same hdmi cable that it came with and played for about 3 hours with no problem so i figured it was the dvd player took it back to bestbuy swaped it for exact same one did the same process again same **** called samsung they told me that if the xbox played fine then its not the tv told me to return the dvd player for another one whats the chance the 3 rd will do the same any one have sugest or know how to fix it im about frustrated
  • 7 more comments
  • Nexus Geefour Jun 18, 2008
    Same happened to me...1080P8+Samsung LN40A530 LCD (both brand new). Got an intermittent "Searching For Signal" message when watching a retail DVD while connected with $40 HDMI 1.3a cable, but plays fine with the AV cables that came with the DVD player. Tested the DVD1080P8 and HDMI cable on another LCD and it worked fine, which led me to believe that the new LCD was to blame. Explained all this to Samsung Customer Support, which didn't help but schedule a service call to repair a 5-day old LCD. Ultimately, I exchanged the LCD for a new one, but still the same problem!!! Now I don't know what's going on...try a new DVD player? cable? LCD?
  • EL MOJADO Jun 20, 2008
    DId u purchase it from best buy i did i think there is a few players out there that were manufactured wrong I returned mine for the 3rd time and walla it worked returend my expensive monster cable and purchased a 30 dollar cable at walmart the vizio kind works the same as the monster cable 79 dollar cable so i suggest to return it till it works its the player that broke well at least the hdmi port just explain to best buy or what ever store you purchesd it from that you called samsung and they said try another because there is a batch of playrs that the hdmi port is bad it took me three times but the 3rd one worked and i also purchased another one for my parents for there 58 inch samsung and it worked i got that one from cicuit city its a little more expensive it was 80 and the one one at best buy was 70 wow big diffrence but go and exchange the player its bad hope this helps
  • henrysdream Jun 28, 2008
    I too just bought a LN40A530 and have the identical problem. I scheduled a Best Buy service repair, so we'll see. Good to know replacing the TV doesn't help. What kind of DVD player are you using?
  • Kit_mtx4 Jul 14, 2008
    We are having the same problem. We have 2 DVD players with up-converter
    to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with
    our Samsung LN-T4053H upstairs, never intermittent.
    LN40A530
    downstairs is having "Searching for Signal" problem. Took it back to
    Sears got a new one, problem followed. Something is wrong with this
    LN40A530. Perhaps firmware update is needed.
    Nexusg4, I'm with you. Something funny about this LN40A530 series.
  • taterinjun Jul 20, 2008
    I am having the same problem with the same dvd player but my tv is a new Samsung 550 series...everyone is blaming their tv's....has anyone confirmed that it is indeed the dvd player issue?
  • cristimacnei Jul 28, 2008
    We purchased same dvd player and a 550 series samsung 40 inch tv and yepper same issue I have been frustrated for 2 days trying to fix this issue. Tried everything to fix this and still same issue.Took back both the tv and the dvd player once and still got same issue lol. Swapped out hdmi cable from back of cable box and my dvd still the same isuue. So only thing I can figure is it is a dvd player issue. But not sure will see if I can figure it out today.
  • amlubin Apr 05, 2009
    New Sony Bravia tv and Toshiba dvd player (low end) connected with hdmi cables.  Some dvd's work, others don't.  Error message is either 'bad disc' or 'loading'.  No discernable pattern to which dvd's work or don't.
  • Anonymous Mar 27, 2014
    dear sir my problem is my tv has a set top box as well as a media box out of the set top box is a hdmi cable which goes into the media box also a have updated my amp the tv is fine the blue ray plays cd ok but when i put a dvd on the tv screen is still on but i can hear the dvd but have no picture the dvd player has an hdmi on the back where does that hdmi go so i can get picture as well as sound many thanks graham.
  • Anonymous Mar 31, 2014
    Can't connect to HLN DLP 5065w tv to blueray player no hdmi port in tv
It is the samgsung upconverter, I completely replaced it with a sony converter and it works just fine. Samsung has said there was a bad lot of those specific players you are all talking about.
Posted on Oct 03, 2008
I also bought the DVD-1080P8 and a TV LCD LN40A530... When I use the DVD player connected to the TV via a Philips HDMI cable, the image blinks few times per minute... However, when I use the same TV and cable connected to my Scientic Atlanta cable HD TV terminal, it works fine... I called Samsung, they recommended me to try to upgrade the firmware. The instructions on ther website are weird (it mentions to check if the file extensio is "ruf", but the file provided has another extension. Anyway, I contacted Samsung, and they asked me to send back my DVD player because they would be going to replace it. But they are not sure if the new replacement player will come with the same firmware version... I no longer can return it to Future Shop. so I will try to sell it.
  • 3 Answers
The problem is with the Samsung DVD having HDMI issues with the Samsung LCD. I ultimately bought a Philips DVD Soundbar and everything works, except for the Anynet+ since it's only for Samsung products. How embarrassing for Samsung for allowing this to happen.
Posted on Aug 14, 2008
DItto here; same problem. I have a new Samsung 32" and a new upconvert DVD. Tried using other HDMI outputs, which made it better but didn't fix.
Posted on Aug 13, 2008
Wow! I'm having the same issue. Brand new Samsung TV and DVD player. Tried getting a new HDMI cable, still doing it. I'm going to return the DVD player to Circuit City. Maybe I should try a different brand DVD player...how wierd...
Posted on Jul 20, 2008
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Posted on Jun 16, 2008
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
I have a PS42B541 plasma TV and a 1080P9 DVD player, but the HDMI interface is not working at all. The DVD player is sending the video signal to the TV, but not the audio signal. Also Anynet is not working...
This is a compatibility problem between this model of samsung dvd player and samsung B model tvs. the only solution to fix this problem is disabling anynet option on samsung B model tvs.
Mar 02, 2010 | Samsung DVD-1080P9 DVD Player
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Problem hooking dvd-1080p8 to 22inch 720p RCA TV LCD HD .
I changed the output on the Dvd player to720p and that seemed to cure the signal problem,that is what the TV is,so that makes sense,I had already assumed that would do the trick.However,as I said yesterday,the manual states it only upgrades the signal in 1080p,I went by the deacription on the box which said it was compatible with all 3 signals.So after all of that I am not sure if it is going to upgrade the signal to 720p,if you have the answer I would appreciate knowing,I can certainly live with this .but it would be nice to know.
Dec 27, 2008 | Samsung DVD-1080P8/XEU DVD Player
Upconversion to 1080i playback
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 15, 2008 | Sony 36IN TV Stand Designed for Model...
Component Cable
Are you just using the yellow cable at this point, because the quality would in fact be awful? Using the green, red & blue cables (component cables) would not improve quality much, seeing as the yellow video cable has a resolution of 480i and component cables are set at 480p. Your TV (if it is in fact high definition) would either run at 720p or 1080p depending on what the manual says and what the native resolution is. I would say try and buy and upconvert DVD player and make sure to get an HDMI cable to go from the DVD player to the HDTV (some DVD players come with this cable, but you'll have to look around for them, otherwise look on buy.com or something for some cheap ones). HDMI connection and the upconvert DVD player will improve picture quality significantly.
Apr 23, 2008 | Televison & Video
So with the upcoverter??
Greetings jhays82,
While I am not familiar with all the models out there, I personally purchased a Samsung upconvert 2 years ago and I could definately see the difference between this and my progressive scan dvd player from before. In searching online for the Panasonic 1080p upconvert, there are several differing opinions, however my suggestion would be to purchase the one that appeals to you and utilize the 30 day return policy if the unit does not work for you.
I hope this helps.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 15, 2008 | Televison & Video
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Televison & Video Logo
1,203 people viewed this question
Top Televison & Video Experts
