Question about LG WM-2277HW Front Load Washer
LG front load washer
My wash is less than 2 yrs. Stinks like mildew. Nothing seems to rid the machine of the smell.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Make sure you are using an HE branded detergent and cut back on the use of fabric softener to start. If you have a wm2077.2177 or 2277 LG has a board that has a tub clean program in it that can help. You can get the same result though by running a HOT bleach wash or use affresh, www.affresh.com It won't do it all in one go but over time it will make a difference. Leave your door open after the wash and wipe down the gasket as well.
You can help the process by changing the gasket, bellows and drain hose or you can try removing them and cleaning them out.
Another detergent on the market that works well is Persil, costs a bit more but you only use about 1/8 of a cup and it will last 3-4 months so is pretty cheap in the long run.
Note it is not the machine that has caused the problem but what has gone in it so try not to use so much and don't mix brands.
It will take a bit of time but you can turn it around.
Sgt 48
Posted on Jun 07, 2008
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lg washer smells stinks
you have a blockage in your drain line. you could snake it, pour drain cleaner in or do both. once your unblock it the smell will clear up.
Sep 16, 2009 | Washing Machines
LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Washer door ring has mildew on it and is causing my clothes to smell moldy. What can be done to get rid of this? I've used bleach, and cleaners directly on the rubber ring, but with out success.
Unfortunately, when mold and mildew impregnate the rubber door boots on these models, it's nearly impossible to get it to go away. I would recommend replacing the door boot and follow these diligent preventive measures to keep the problem from coming back: 1. Check the area in and around the door boot after each wash for lost articles of clothing like underwear and socks. Also, clean out any lint or debris that collects under the boot. You might want to think about using a mesh garment bag for small items in the future. 2. Wipe the area periodically with a towel to get rid of the accumulation of soap deposits and dirt. This means wiping BEHIND the door boot where it meets the wash tub as well. I recommend waiting until you get ready to do a load of towels. Clean the area with a towel, then throw it directly in the wash. 3. Leave the door OPEN between washes to allow the door boot to air dry. Due to the nature of these door seals, they seal air tight and create an environment for mildew and mold to grow. 4. Run the washer with no load on the hottest cycle you have with nothing but bleach about once a week to keep bacteria to a minimum, and to flush the drain lines and pump. The door boot costs about $80 to replace, but it may be your only solution to getting rid of the smell and bacteria. Let me know if you decide to replace it. I can give you some pointers.
Jul 28, 2007 | Kenmore 44072 Front Load Washer
LG WM-2277HW Front Load Washer Logo
102 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
