Cars & Trucks Logo
george bato Posted on Oct 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My car is a 89 toyota corolla the engine is a 2E my problem is at hi speed the exhaust turns red which you dan lite up acigarette .what do you think could cause this type of a problem
Anonymous
Level 3:
  • Master 395 Answers
  • Posted on Oct 22, 2010
Anonymous
Master
Level 3:
Answers
395
Questions
0
Helped
160054
Points
1163
It is quite normal for the exhaust manifold to get very hot, especially when the engine is working hard running at high speed under load. Every time the mixture in the cylinder is ignited there is a small explosion producing a big flame and a lot of heat to push the piston down A lot of this heat goes out the exhaust. During daylight it is usually not noticeable, but at night it will visibly glow up to a bright red.
Toyota tazz 2e cuts while drive
no year car, 2E ,(engine) nor country told.
no is africa, a stripper car. SAID WIKI , NONE SOLD IN USA
SO NO PARTS HERE OR BOOKS ON IT ZERO.
Toyota Corolla (E90)
stalls fast, like a light switch engine RPM to zero
or falls slowly, as in fuel lost ,but wait....
but you said spark is dead and I believe you.
new coil, new distributor, or just cap and rotor. AND HV SPARK LEADS, NEVER TEST JUST ONE LEAD TEST THEM ALL.
SEE? THEN LEARN WHAT IS REALLY WRONG.
'COIL DEAD?
then ICM>SO IS CARB fueled engine RIGHT?
real name of engine, A Corolla name change. car. AFRICA?
  • Petrol:
  • 1295 cc 2E I4
1996?????????
more
The 2E is a 1.3 L (1,295 cc) SOHC version with three valves per cylinder. Output ranges from 65 to 88 hp (48 to 66 kW; 66 to 89 PS) at 6,000 rpm with 72 lb?ft (98 N?m) of torque at 3600 rpm to 77 lb?ft (104 N?m) of torque at 5200 rpm. It appeared in 1985, and was discontinued after 1998. The 2E engines appeared in both carbureted and fuel-injected (called 2E-E) versions. The 2E-TE, appearing in 1986, is a turbocharged engine producing 101 hp (75 kW; 102 PS). A later version, the 2E-TELU produces 110 hp (82 kW; 112 PS).
How many intake valves does a toyota tazz 2e engine 2004 model have
earlier 2Es have one inlet one exhaust
after the east west front wheel drive were introduced
most 2E toyota engines have three valves per cyl
two inlets and one exhaust
if you need the correct information on your 2004 2e engine
,,,,undo the rocker cover
Where is the exhaust gas recirculation valve located on a 2e engine.
Hi. The exhaust gas recirculation valve is located by the transmission fluid dipstick. This is yellow and is labelled as 'TRANS FLUID'
2answers
My toyota 2e 12 valves engine newly overhauled but white smoke is too much in exhaust pipe and the engine oil has rans out
Head gasket leak, white smoke is antifreeze leaking into combustion chamber, do not run it will ruin engine! replace head gasket and check heads for warp
1helpful
1helpful
4 and 5 speed tranny for corolla 2e
When looking for a "faster" transmission you need to check the actual individual gear ratios of each gearbox and match anticipated rpm to available peak torque of the engine. This gets a bit complicated but likely if you speak with anyone who drag races a similar vehicle they can hook you up with charts & formulas. As far as top speed goes, that's all determined by your engine and differential/tire combination as all units are 1:1 in fourth gear (fifth gear is overdrive and may give you slightly more top end) For a street car, there are far easier ways of wringing out a bit more performance.
2answers
Toyota Corolla 1.3 2e
To my knowledge, it should not loosen up by itself. If it does, then it is possible that they are worn out and must be replaced. Alternately, on some engines I have worked with, there is a locking nut that is used to tighten in place the adjuster stud or in some cases a double nut, that is one nut to lock in place and another to lock the first. On high revving bike engines, I also use locktite (superglue). Of course the pieces must be initially clean of oil otherwise the glue will not adhere.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Toyota 1.3 2e
what valves are you refering to? there is many valves in a car other than the engine valves
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
