Question about GE WBSE2090A Top Load Washer
Washer will not fill
The water level / load size switch broke and now no water fills. Do you think it's the pressure and how do I fix it? Many thanks.
- sam
  • Wilco777 Aug 04, 2008
    Thanks for taking the time to reply. Much appreciated. I fixed it by removing the back of the front cover where I noticed the spring dial was turned too far. Just has to reset the spring loaded dial back there and all is good now. cheers.
I had a problem almost like yours. The hose attached to the load size switch had a clog in it, and the washer wouldn't fill with water or spin. Will need to take the front panal off to check the whole line.
Posted on Aug 03, 2008
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
I have a model lse7806ace maytag stackable washer/dryer unit. Initially, the washer would not do anything. I replaced the lid switch and it then filled and agitated at the same time... but when it went...
Ok , when you pull out the washer knob to start it the water fills . Can you stop the filling by pushing the knob in? if so the water valve is ok.
There is a sensing tube from the tub which connects to the pressure switch. This is what causes the water level pressure switch to shut off at the correct level. I would suspect this as they replaced the pressure switch and it keeps filling. If this is the case there is a small hole which will cause the pressure switch not to turn off the fill valves.
You can check this by removing the tube and submerging it in some water then blow in the tube while blocking the other end , if you see bubbles it is leaking and needs replacing.Hope this helps
Feb 19, 2011 | Maytag LSE7806A Top Load Stacked...
I have a whirlpool ultimate care II that won't fill with water it just starts agitating. Sometimes if you hold the load size switch in between load sizes it will start filling but you have to hold the...
The problem is quiet obvious and it is the water level pressure switch behind and connected to the load size switch knob. The pressure switch is stuck in the full position that's why the machine doesn't fill and it goes directly to agitate. Holding the load size switch in between load sizes releases the contacts from full position and allow the machine to fill as long as the switch is held on.
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Behind and connected to the load size switch under the console is the water level pressure switch with a clear hose attached to it.
Remove the pressure hose from the pressure switch then reinstall the console and reconnect power. Start The pressBlow air forcefully into the pressure swic
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Elba WA50T54W1 water just overflowing not cutting of when full
water level pressure switch tube is clogged with lint or bladder in pressure switch is bad. disconnect power to washer open timer console look for a clear rubber hose disconnect fron switch and blow in tube a couple times reconnect tube and put unit on drain and spin for a second then retrying unit for water level fill put washer on small load water size and test if it continues to fill replace pressure switch...
Jan 23, 2011 | Washing Machines
My Cabrio no longer adjusts water level according to load size. It fills to the max each time. How to fix?
problem most probably in clogged pressure hose leading to pressure switch or bad pressure/level switch itself.  you can try cleaning the hose by simply blowing into it after disconnecting it from the pressure switch.  a simple fix but if clogged, it usually works.
Aug 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer keeps filling no matter the size I have
This sounds like a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start appropriate cycle. Make sure there is no damage to or obstructions in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Jun 18, 2009 | Whirlpool Washing Machines
My washer wont stop filling up.cold and warm work but it doest know when to stop filling up hot doesn't work at all.please help my water bill was really high this month it a kenmore 80 series...
There is a defect or , malfunction within the Water fill level pressure switch. this switch will cost about 35 dollars and, it should be replaced asap.it has failed.
Replacing the
Water fill level pressure switch, will fix your issue.
Jun 16, 2009 | GE WBSR3140DW Top Load Washer
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Whirlpool ultimate II water level problem
does it still fill when you unplug? if it does then the fill valve is no good.if it turns off the check your hose going to pressure switch.will be a small clear hose going from tub to your pressure switch.
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WBSE2090A Top Load Washer Logo
98 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
