Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper feed When I print the printer grabs more than one paper. Sometimes this jams it up. This starting happening after an envelope got stuck and was removed.
    Problem Solver:
  • 15 Answers
When the paper is in the feed section there is a rubber pad on the underside and a rubber roller on the other. Try cleaning the rubber pad with a cytrus cleaner or just water, on a rag. Do not hesitate to "rough it up" a bit. Only helps the cause.
NOTE: if your machine has a "cork" pad rather than "rubber". Do not clean with a solution and only rough it up slightly.
Also check that your machine does not have a paper/envelope selector (often found in the paper exit area). If so ensure it is set for paper.
Posted on Jun 13, 2008
Unable to close error message "Paper Jam"
unplug the printer, inspect it for paper jams, take the printer apart as far as possible and clear any paper jams in it.
for more specific instructions I will need to know the brand and model of your printer.
Thank,
Ekse
Jul 07, 2008 | Office Equipment & Supplies
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
Manual feed won't grab paper
If the printer works good when it prints the envelopes/label one by one, I think it works normal (because the paper is not a standard paper).
Mar 06, 2014 | HP Office Equipment & Supplies
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Printer thinks there's no paper...but there is!
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Sep 28, 2006 | Lexmark X85 All-In-One InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
35 people viewed this question
old marine
old marine
