Tub is not spining during spin cycle and the water drained out the bottom of my hotpoint, 10 years of loyal service. Did she die on me?
  • darcicreer Mar 12, 2009
    how do i remove the back of my washer to check the belts?
How do I remove the back to check the belts
Posted on Jun 06, 2008
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
New Hotpoint washer purchased Nov.2010.....Problem 1. Fills, agitates and "drains" NO SPINNING this cycle. #2. Rinse fills with ONLY ABOUT 6-7 gallons of water, agitates about 10-15 seconds then...
may have a bad pressure fill switch and thats the reason not filling all the way have you tried on different load sizes... if this is a top load unit need to check the fill hose that goes from side of tub to pressure switch in console make sure has no cracks or kinks in it... what happens is water fills tub and then pressure from tub water goes up clear plastic hose to pressure switch to tell it to advance to next cycle... may be your culprit. and causing other problems... as far as clothes tearing beware hotpoint had a issue with there tubs coming loose the nut that holds down tub will back off causing exess movement and will allow clothes to get under unit... this unit should be still under mfd warranty... call g.e and get a servicer out there to look at it.. at worst you may have to pay a service charge but parts should be covered along with labor.... good luck pleae vote./...
servicer for 18 yrs heating /air / and all major appliances g.e authorized and lg. authorized for 8 years
Jan 03, 2011 | Hotpoint Washing Machines
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
