I needed to change my color cartridge and I got the photo cartridge it fits fine I ordered from Dell but I keep getting an error message saying no cartridge in the right side
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Hi, you are facing this issue as your Black ink Cartridge is empty, if you open the hud of the printer you will see there are two Cartridge, one is for Color and one is for Black, your color cartridge is fine as it will printing properly. In order to resolve the you need to change the color cartridge. If you want to replace the Cartridge by your own below weblink will help you:
the contact that detects the left cartridge may be dirty or not functioning at all. clean it with cotton and 100\% isopropyl alchohol then reinsert the cartridge. if it still doesn't work, it must be replaced.
Ok
Be sure the power cord is in place. and the power is turned on. Next lift the lid and give it time and the ink cartridge will come to the center or left side so you can change them.
Hope this is helpfull to you. Sawdust46
Since you already replaced the cartridges there is a problem with the printer.The cartridge must have made the pinter bad.Now you have to take it to the Service Center.
Regards
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
If your Dell Printer is not working properly or you're facing technical problems setting up your printer and you want professional technician executive, this is when we step in. Dell Printer Customer Care Phone Number +1-833-260-7367
we have provided you the best dell customer support. when you facing any technical issues in dell printers. If you and your friends need and ask the best for dell printer services, you only need to https://easysupportnumber.blogspot.com/
is it a refilled cartridge? if it is it wont recognice it u should just buy a new one or keep printing if it lets u because i had the same problem and i had to get a new cartridge because it wouldnt let me print at all
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
