Question about Dell P1500 Laser Printer
Dell P-1500 laser printer
At startup my printer has 4 lights on (solid). They are the Ready, Low Toner, LOad/Remove, & Paper Jam lights. The printer does not function in the state.
    Problem Solver:
The best solution, step to step:
1.- Delete all files of all printers instaled in the computer, using < Control Panel/Printer and Faxes > on this screen delete all printer previosly installed.
2.-Download and save on desktoc, from this link, the driver http://www.dell.com/support/drivers/us/en/04 select, your operative system and dpwnload the driver and SAVE.
3.- On the salved file driver, double clic, and follow the screen, where are installed, in all computers this file are Unzip on C:cab/DELL/driver/printer.
4.- Run Add Hardware Wizard, and follow the screen. If the Wizard need addicional file, locate that on C:cab/DELL/driver/printer, and continuos the wizard to at end.
5.-Afther receibe the screen "Completing HARDWARE WIZARD" , Restar the computer, and wait for reinicie.
6.-Use any document to Order PRINT, check the Printer status.
Posted on Jul 01, 2012
How do i install dell p1500 without cd
Posted on Mar 21, 2009
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
What do the flashing light mean on a lexmark E260D. please help
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
Jun 24, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Lexmark E120 not printing. The printer is set in network. The two red leds are on after turning on the printer. toner has been replaced but problem not solved. the printer green led is off. what is the...
This model has an operator panel with six lights and two buttons. It has Cancel button, Continue button, Ready/Data, Toner Low, Load/Remove Paper, Paper Jam and Error light. We would like to know which light on the panel has a red light.
Please provide us information and we
Jun 08, 2011 | Lexmark E120n Laser Printer
What does the second warning light on the lexmark printer e260dn mean? and how do you fix it?
We would like to know more about the second warning light you're referring to. Is it the second light from the left or from right side. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information if the light blinking, slow blinking or solid light.
Feb 23, 2011 | Lexmark E260dn Laser Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Dell P1500 Laser Printer Logo
355 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
