Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC Television The top of the picture is perfect however the bottom half of the picture has black lines and the picture jumps
  • Eugene Martinez Jun 05, 2008
    I have a JVC television and the picture shakes or jumps. It also has black lines at the bottom of the screen.The picture doesn’t disappear or anything but a portion of the screen will shake and/or flicker.
    Does anyone know what these symptoms indicate? Does this mean my TV is dying? I appreciate any assistance anyone can offer.
    Novelist:
  • 132 Answers
1024x768 Normal 0 Convergence
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Posted on Jul 07, 2008
Panasonic TH-50PX70EA HAS A HALF SCREEN PERFECT BUT OTHER HALF IS LINED AND CHANGES COLOUR AND SOMETIMES GOES BLACK GETS CLOSE TO PERFECT THEN GOES LINED AGAIN PS sorry for caps
If its a Plasma it uses sustain or t con boards--sustain will usually be two--one for left side and one for right.
Only boards are sold for these sets--no individual parts--discover which board drives the right side and replace it while crossing your fingers--either it fixed the problem or you have a bad display panel (entire screen unit which is fatal from a cost point of view).
Apr 22, 2012 | JVC PD-42WV74 42 in. Plasma EDTV
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Top half of screen
Blue STK392-040 Convergence IC bad = replace both with
first quality parts = NO generics,they don't hold up. I USE
PANASONIC with great success................T.
Dec 02, 2007 | Akai PT4298HD Rear Projection Television
Television fault
it is not worth fixing get a new tv
Oct 31, 2007 | JVC AV-27020 TV
Half Screen
take it apart and check the cables to see if they are seated properly, if you hit it and it comes back, then something is not connected good
May 25, 2007 | RCA PHD50400 50 in. Plasma Television
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
Top half of screen looks like 3D
the prob. described points to convergence amp failure. have qualified tv tech to repair..john
Nov 10, 2006 | Akai PT4298HD Rear Projection Television
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
