Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
My sony wega 36' circa 2001 will not receive cable signal.
It works if you use a cable box but not a direct cable plug from the wall. I don't have a box and need it to work.
  • slewis39 Jul 06, 2008
    my wega does not get signal thru cable rf but gets signal thru ant rf. Im running cable thru cable box hooked to rca.
    Novelist:
    Champion:
  • 203 Answers
If none of the r.f. inputs are working and you do not get local channels off of a pair of rabbit ears. You may have a bad tuner. Which you can get replaced for 125.00-150.00 or you could run the cable into a vcr input and use audio/video cables to connect to a video input on the tv and switch tv to that input and run the channels using your vcr. In other words, use your tv as a monitor and use the vcr tuner to pickup basic cable. Hope that takes care of it, Russmann.
Posted on Jun 13, 2008
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
Viore LCD26V37HA Won't Work With Cable
where did you hooked up the cable box, how about the settings in the tv did you checked?.
Aug 15, 2012 | Viore Televison & Video
We have used this TV as a primary hooked directly to the cable box. Now we bought a larger Sony and want to put this one in another room. We unplugged the set from the cable box carried it to the other...
first, be sure the cable outlet is working. If so then you have to reprogram the tv by doing a channel search in "analog" since it's no longer connected via a "digital" box. Just go to the tv menu, search channels(analog) and start.
Jul 21, 2011 | Televison & Video
I turn on the cable box and the tv and about 1 minute to 4 minutes later the tv short circuits and turns off. The cable box is still on. The cable company came to change the box and the cables but it...
Sounds like there is too much voltage going into the same outlet. Please keep in mind cable boxes as well as your tv hold a higher amount of voltage then your dvd player. If your tv is plugged into the back of your cable box, unplug that and just plug it directly into the wall. If not, get a power strip and plug it in that way.
Nov 20, 2010 | Televison & Video
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
Is there any way to connect basic cable to the tv without using a converter box or anything else
Recently, I dropped HBO with my cable company and there dont have a box. Since the Maxent 42 is only a monitor and doesnot have a tuner...there is no where to plug cable from the wall to the tv.
Solution...plug cable from wall to VCR/DVD and then use RCA cables (Red,White and Yellow cables) from output from VCR/DVD. works great.
Nov 22, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
We lost power the other night when it cam on there was no power to my cable box or tv the outlets still work because i plugged something else in them is there a reset button on the tv
Is the TV connected directly to the outlet in the wall or through a power outlet on the cable box? If so connect the TV directly to the wall and see at least if it does power up. If it does than the cable box is bad and will need to be replaced. If neither the cable box or TV power up when connected directly to the outlet then the possibility is you had a power surge that damaged both.
Nov 17, 2009 | Televison & Video
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
