Question about Kenmore Elite 45986 Front Load Washer
Washer doesn't drain or spin
Kenmore model 110.22882101 washer doesn't drain or spin
  • Anonymous Dec 23, 2008
    washer makes loud buzzing sound and won't spin or drain. What do you think is wrong?
    Genius:
  • 1,028 Answers
Remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Posted on Jun 06, 2008
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Washer not spin
I have a Kenmore 60 sirce washer it drains put won't spin
Dec 07, 2013 | Kenmore 24032\24036 Top Load Washer
Will not drain and spin
see this causes:
t spins, but doesn't pump
the drain line is clogged+ some sock remain, remove with pliers,+pump defective.
It doesn't spin or pump
frozen pulley pump defective, replace
It pumps, but the water returns
improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly.
see diagram
God bless you
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
KENMORE WASHER MODEL 110 92588210 DRAINS WATER DOESN'T SPIN
You might have an issue with the spin gear in the gearcase.
May 31, 2012 | Kenmore Washing Machines
Kenmore 80 series washer will not drain or spin but will fill up how to fix it
The usual thing wrong when a washer such as the one ya have doesn't spin or drain,it's going ot be a broken lid switch. Its a pretty common thing so i have written this tip of how to check for a broken lid switch, http://www1.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Oct 10, 2011 | Kenmore 24032\24036 Top Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
194 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
